Toymods » Tech & Conversions » catback keeps melting
da20v
quakers hill
catback keeps melting Sat, 14 August 2004 02:28 Go to next message
hey guys im having this problem where my catback keeps melting....just the other night wen i was driving my car on the freeway the car start to jolt then suddenly this clanking noise start to come on...& i know its the cat back again bcoz i have had this happen b4...i replaced my catback 3 times already in 3 months & its costing me.....wat do u reckons causing dis problem maybe a bad ignition system??, spark?, or replace spark plugs but ive got the iridium ones in there .... the engine is a silvertop 20v & i always put premium unleaded
cheers ramon
[Updated on: Sat, 14 August 2004 02:29]
AE86slut
Baulko Hillo
Re: catback keeps melting Sat, 14 August 2004 03:01 Go to previous messageGo to next message
I'm assuming you are taling about your catalytic converter, not your exhaust from the cat back?
Check your timing and ignition system.
BlackSupra
Re: catback keeps melting Sat, 14 August 2004 03:23 Go to previous messageGo to next message
Im guessing the cat is having a bunch of fuel dumped into it?
Re: catback keeps melting Sat, 14 August 2004 03:49 Go to previous messageGo to next message
you must be running uber rich to get enouh unburnt petrol stuck in the cat.
spark timing might be an contributor (e.g. firing too late at higher rpm), but choice of plugs isn't going to dramatically affect the life of a catalytic convertor.
have you disabled/broken the O2 sensor? ECU might trying to run closed-loop and if it gets erronious or suspect O2 sensor signals it will incorectly fuel the motor at cruise and idle (e.g. ECU might think engine is hovering around stoich, when in fact it's so out of tune, the cat's turned into a furnace).
Super Jamie
On Probation
North East NSW
Re: catback keeps melting Sat, 14 August 2004 09:07 Go to previous message
your cat back exhaust system keeps melting? god damn, how many times have i told you not to use pvc pipe as an exhaust!!!
Previous Topic:handbrake? (ae82)
Next Topic:1GGZE into 1984 4x4 Hilux
Current Time: Fri Oct 23 11:50:53 UTC 2026
Total time taken to generate the page: 0.004371166229248 seconds
