Toymods » Tech & Conversions » handbrake? (ae82)
carsanactra
melbourne
handbrake? (ae82) Sat, 14 August 2004 03:35 Go to next message
hey guys.
i was just wondering how i go about tightening me handbrake? it seems that if u do even like one handbraky around a corner or something then it works once, and then is to loose to even be considered a handbrake after that?
how does a mechanic tighten the handbrake when he does a service to ur car?
Rowan
Re: handbrake? (ae82) Sat, 14 August 2004 04:41 Go to previous messageGo to next message
ae82 handbrakes are always pretty shit in my experience. i've had three twin cam corolla's and only one of them has had a good hand brake. on the other two i've had you have to apply brake pressure with the pedal first then pull the hand brake up for it to work at all. I could be going along at 100km/h and pull the handbrake up and it does nothing at all.
Apparently the rear brake calipers can get damaged if you dont use the correct tools when changing the brake pads. the calipers need to be 'wound-in' rather than 'compressed-in' (the front ccalipers just need to be compressed.) if they are compressed in they fu*k up and the handbrake will no-longer work properly.
I may stnad to be corrected, but I hope this helps all the same...
Super Jamie
On Probation
North East NSW
Re: handbrake? (ae82) Sat, 14 August 2004 09:15 Go to previous message
you can adjust the shoes up, or you can tighten the nut at the handbrake lever. eventually you'll run out of adjustment and need to buy a new handbrake cable, really you'll probably snap the cable first
Previous Topic:How do i rip out the dash?
Next Topic:catback keeps melting
Current Time: Fri Oct 23 10:10:53 UTC 2026
Total time taken to generate the page: 0.0056319236755371 seconds
