Toymods » Tech & Conversions » AE86 brakes on a KE10
smitty1
AE86 brakes on a KE10 Sun, 15 August 2004 10:47 Go to next message
I know that KE70 brakes will fit with a wheel bearing swap onto a KE10, but will the vented discs off an AE86 fit?
smitty1
Re: AE86 brakes on a KE10 Fri, 27 August 2004 02:38 Go to previous messageGo to next message
Does anyone know? What I'm after is a vented disk conversion that will fit inside 13" wheels.
ae95
Re: AE86 brakes on a KE10 Fri, 27 August 2004 03:32 Go to previous messageGo to next message
Just letting you know the vented front disks are found only in the jap ae86's. the aus spec ae86's came with solid disks up front.
The jap and aus spec brake will fit inside 13" wheels
smitty1
Re: AE86 brakes on a KE10 Fri, 27 August 2004 11:39 Go to previous messageGo to next message
Thanks ae95, I actually knew that it was only the JDM sprinter that had them, but I thought that they might have the same mountings as the KE70 disks. I guess if it was that easy, anyone with a KE1x or KE2x would be chasing a set.
aeke
Re: AE86 brakes on a KE10 Sat, 28 August 2004 07:29 Go to previous message
The KE70-KE50 brakes bolt straight to the Ke20 hub on the ke10 strut so you dont have to change the wheel bearings. I had a booster in my KE10 out of a Honda civic with a bigger master cylinder and that made the KE20 brakes feel realy good. With the KE50 - 70 brakes, good pads, booster and a bigger m/s that would be much cheaper and a lot easier then trying to fit AE86 brakes. I am not sure but I don't think the AE86 brakes will fit KE10 struts because the caliper offset is different but i could be wrong. AE86 vented disc's and calipers cost a fortune and a hard to find so you might be better off going with something different.
Previous Topic:4age 20v putting turbo or 4agze motor please advice
Next Topic:Cairns 4agte aw11 mr2
Current Time: Mon Nov 23 19:32:39 UTC 2026
Total time taken to generate the page: 0.0075340270996094 seconds
