Toymods » Tech & Conversions » Removing W5? from 4AGE while still in the car
rallysprinter
Hobart
Removing W5? from 4AGE while still in the car Sun, 15 August 2004 11:50 Go to next message
I've got a W5? gearbox with custom bellhousing bolted to a 4AGE in my AE86 and I need to pull the gearbox out to fix an oil leak.
My problem is that I've got all of the bolts out except for the top 2 bolts, but I just can't anything on them. The bolt heads are recessed in the bellhousing so only a socket will fit, but there's only just enough room between the firewall and the bolt head to get the socket on, no way near enough to get a socket with ratchet on.
Is it possible to get the 'box out by itself or does it mean dragging the engine and box out at the same time? Is there some fancy tool available to get those bolts out?
Anyone else got any suggestions?
Re: Removing W5? from 4AGE while still in the car Sun, 15 August 2004 12:29 Go to previous messageGo to next message
I have a similar problem with my Supra. I've had the gearbox out more times than I care to recall (don't ask) and my solution was to tilt the engine back as much as possible, which makes the upper bolts accessible from under the car. You may need to use a fairly long socket extension and uni-joints can be useful too, but you'll probably find it's quite possible with enough patience and care. Just remember to disconnect anything from the engine that doesn't have enough stretch in it, eg exhaust, radiator hoses etc.
Good luck!
Re: Removing W5? from 4AGE while still in the car Sun, 15 August 2004 12:36 Go to previous messageGo to next message
Yup, I've got the same problem, I've got a W55 in an AE86, I find that I can get it if I undo the engine mounts, and put a jack right under the front corner of the engine, tilting it back. It's all tight, but it is doable.
rallysprinter
Hobart
Re: Removing W5? from 4AGE while still in the car Mon, 16 August 2004 07:39 Go to previous messageGo to next message
Thanks Guys, you've saved me some time and effort there. I'll give it a whirl next weekend.
SEXY 16
ghetto area 2745
Re: Removing W5? from 4AGE while still in the car Mon, 16 August 2004 07:46 Go to previous messageGo to next message
is this o`donaghues old car???
rallysprinter
Hobart
Re: Removing W5? from 4AGE while still in the car Mon, 16 August 2004 22:48 Go to previous messageGo to next message
Possibly. I bought it from Cathy Donohue in Canberra in early 2003.
SEXY 16
ghetto area 2745
Re: Removing W5? from 4AGE while still in the car Mon, 16 August 2004 22:57 Go to previous messageGo to next message
you beat me 2 it you bought it very quick as i recall
rallysprinter
Hobart
Re: Removing W5? from 4AGE while still in the car Tue, 17 August 2004 00:21 Go to previous messageGo to next message
Yea, I saw an AE86 rally car for sale in Ballarat in late 2002 and decided to sell my Datsun 1600 rally car. By the time I sold my car, that AE86 was also sold and I was without a rally car. So when this one came up on www.rally.com.au, I got right onto it. Ended up buying it from just the photos.
But very happy with it other than being a bit heavy for just the standard 4AGE.
SEXY 16
ghetto area 2745
Re: Removing W5? from 4AGE while still in the car Tue, 17 August 2004 23:24 Go to previous messageGo to next message
from what i recall my brother drove this car and said it was 1 of the best prepared cars he had ever seen apart from the gearbox gap between gears was to high and the car felt like it was loosing power"no offence"
have you done anything to the motor yet
rallysprinter
Hobart
Re: Removing W5? from 4AGE while still in the car Wed, 18 August 2004 00:13 Go to previous message
It is certainly very neat. I had the engine dynod but didn't find any more power. The rev limiter was at 6,500rpm. We reset the limiter to cut at 7000 but put the change light to 6,500rpm as max HP (62rwkw) is at 6,200rpm.
With the underbody protection, the steel cage, the W5? and G series diff it weighs in at 1050kg before the crew jumps in.
Charades I compete against have better power/weight.
Haven't done anything to the engine since, but I now have adjustable cam sprokets, redline manifold and a set of dead 40mm webers to make QTB's, ready and waiting and I'm looking into a set of wade cams, something like 288/272.
Previous Topic:4K with 2 speed toyoglide :D rocks!!
Next Topic:Oil pressure sender frequency
Current Time: Sun Nov 29 01:20:23 UTC 2026
Total time taken to generate the page: 0.095453023910522 seconds
