Toymods » Tech & Conversions » how to remove oil pressure regulator?
ae82boy
how to remove oil pressure regulator? Sun, 15 August 2004 13:34 Go to next message
hi all dose any one know how to remove oil pressure regulator,
i want to replace it,will a adjustable spanner work?
also will i need to drain the oil?
STR8 2.8
Re: how to remove oil pressure regulator? Sun, 15 August 2004 14:10 Go to previous messageGo to next message
really depends on where it is located.
what engine?
if its a 5mge i can tell you its only a few bolts.
but im guessing its a 4a of some description.
Confused
adjustable spanner? Shocked never use such a meat axe on fragile toyota bolts! Laughing
get a socket wrech or some ring spanners.
ae82boy
Re: how to remove oil pressure regulator? Mon, 16 August 2004 05:16 Go to previous messageGo to next message
yeah its a 4age ae82.
ed_ma61
Lost in the K hole
Re: how to remove oil pressure regulator? Mon, 16 August 2004 05:48 Go to previous messageGo to next message
STR8 2.8 wrote on Mon, 16 August 2004 00:10
Confused
on M series engines the oil pressure regulator is integrated with the oil pump, and consists of a ball valve type spring loaded bypass.
there is a secondary regulated oil cooler bypass valve fitted to the side of the block under the oil filter on some vehicles, but this is not the oil pressure regulator...
same with the 4a i suspect
[Updated on: Mon, 16 August 2004 05:49]
Re: how to remove oil pressure regulator? Mon, 16 August 2004 05:57 Go to previous messageGo to next message
yes 4age is the same, oil pressure regulator is the ball and spring delive located inside the oil pump housing. Removable with an alan key i think - hence an ajustable spanner will work about as well as my wang would at removing the pressure regulator.
Personally i think you are referring to the oil pressure SENDER. you will need an open ring spanner, with a bent end.... i have a special tool at home which does this job.
STR8 2.8
Re: how to remove oil pressure regulator? Mon, 16 August 2004 10:34 Go to previous messageGo to next message
ed_ma61 wrote on Mon, 16 August 2004 15:48
Confused
Confused hmmm
tsrm shows it with three bolts and a gasket.
ed_ma61
Lost in the K hole
Re: how to remove oil pressure regulator? Mon, 16 August 2004 13:09 Go to previous messageGo to next message
hmmm, me thinks not...
the "relief valve" on the oil pump is the engines oil pressure regulator:
http://www.cygnusx1.net/supra/library/TSRM_MKII/lu/LU_004.gif
what i think youre thinking of is the lash adjustment pressure regulator - this only controls pressure to the timing train as the 5mge runs a hydraulic lifter assembly. this in no way regulates the oil pressure of the 'engine'. 4a's dont have such a lash adjustment regulator.
[Updated on: Mon, 16 August 2004 13:12]
STR8 2.8
Re: how to remove oil pressure regulator? Mon, 16 August 2004 13:15 Go to previous messageGo to next message
ah well there you go!
i stand corrected
ae86drift
sydney.au
Re: how to remove oil pressure regulator? Mon, 16 August 2004 13:18 Go to previous messageGo to next message
THE WITZL wrote on Mon, 16 August 2004 15:57
whats the WST number on that one? Laughing
ed_ma61
Lost in the K hole
Re: how to remove oil pressure regulator? Mon, 16 August 2004 13:19 Go to previous message
kind of academic really as i think (as karl also suggested) he probably just means oil pressure SENDER...
Confused
changing the oil pressure regulator is a Major PITA
Previous Topic:E70 Corolla Steering
Next Topic:TF Magna "Grinding Sound" whilst cornering?!?!
Current Time: Fri Nov 20 18:09:20 UTC 2026
Total time taken to generate the page: 0.0064988136291504 seconds
