Toymods » Tech & Conversions » mikuni 40 twincarb backfiring. need some help
Moonbreaker
icon5.gif  mikuni 40 twincarb backfiring. need some help Sun, 15 August 2004 14:43 Go to next message
i just installed a second hand carb i got for my 13t-u, rebuilt it and modded it to fit a 2tg intake manifold. the problem now is even though i've adjusted the flaot levels, accelerator pump lever arm, sync, a/f screws and idle, the barrel for the first piston is still back firing. which in turn causus the exhaust to back fire as well under load. any ideas on what's wrong? btw the vacuum advance is disconected and the timing set at 10 btdc and the setup has airhorns and no filters.
Jonny2TG
Tasmania
Re: mikuni 40 twincarb backfiring. need some help Sun, 15 August 2004 15:13 Go to previous messageGo to next message
It probably have a air leak. Take the carb off the manifold again, clean both surfaces, and re-install with new sealant or gasket. Do not use silicon as the sealant. Use a paper gasket with No.3 or No.4 gasket sealant.
And make sure any unused vacuum ports are block off.
Moonbreaker
Re: mikuni 40 twincarb backfiring. need some help Mon, 16 August 2004 09:11 Go to previous message
bumped up the timing around 5 degs and the popping went away.
Previous Topic:URGENT - 2Y Wiring Diagram
Next Topic:Oil on Plugs
Current Time: Fri Nov 20 22:03:44 UTC 2026
Total time taken to generate the page: 0.0039489269256592 seconds
