Toymods » Tech & Conversions » Tacho shorts out ignition system
ta2272
icon4.gif  Tacho shorts out ignition system Mon, 16 August 2004 02:23 Go to next message
Was installing efi on my 2tg but it would keep conking out when driving, when fiddling with a million things it came down to the tacho when it was disconected it went fine, when connected it concked out often, anyone know why and how i could get it working.
the tacho is on a ta22 stock tacho.
Jason thanks
Re: Tacho shorts out ignition system Mon, 16 August 2004 02:44 Go to previous messageGo to next message
Hmmm odd. Do you have the tacho signal wire connected to the -ve terminal of the coil? Check the wire for any signs of damage; if it's earthing against the body somewhere that might cause problems.
ta2272
Re: Tacho shorts out ignition system Mon, 16 August 2004 05:11 Go to previous message
yep was on the negative of the coil, i will check the wire but it was only shorting out the electronic system it would nto short out the points/Carbies system.
Previous Topic:what is this broken thing on my gze
Next Topic:4K worked
Current Time: Thu Oct 15 11:03:25 UTC 2026
Total time taken to generate the page: 0.0046749114990234 seconds
