Toymods » Tech & Conversions » Differences between RA60 & RA65 struts?? Any takers
CEL023
Newy
icon9.gif  Differences between RA60 & RA65 struts?? Any takers Tue, 17 September 2002 11:07 Go to next message
No Message Body
CEL023
Newy
icon11.gif  Re: Differences between RA60 & RA65 struts?? Any takers Tue, 17 September 2002 11:11 Go to previous messageGo to next message
Allright so its late, but someone got to be out there.
Am thinking about a brake upgrade for my TA23(currently running an 18rgu).
Mate of mine has upgraded the RA60s already with little effort needed, but i can only find RA65 struts, calipers and discs around.
So are they much difference??
Re: Differences between RA60 & RA65 struts?? Any takers Tue, 17 September 2002 23:51 Go to previous messageGo to next message
From memory, there shouldn't be any.
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
icon14.gif  Re: Differences between RA60 & RA65 struts?? Any takers Wed, 18 September 2002 00:44 Go to previous messageGo to next message
Yeah, I'm pretty certain that they're the same.
celicamad85
Banned member
icon14.gif  Re: Differences between RA60 & RA65 struts?? Any takers Wed, 18 September 2002 01:59 Go to previous messageGo to next message
dude they are one and the same so are the struts from a ma60 or ma61 supra
wayne
CEL023
Newy
icon10.gif  Re: Differences between RA60 & RA65 struts?? Any takers Wed, 18 September 2002 12:39 Go to previous messageGo to next message
Thanks guys, They seem to go pretty much straight in, just the one minor adustment of welding up one of the holes in the TA control arm (the one where the bottom of the strut bolts together with the arm) and re-drilling it about 5-10 mls wider apart. A mate of mine has already done it in his TA22, looks neat enough, most importantly though, plenty of clearance between the strut and surrounding areas.
Perfect, should be a couple of weeks and it will be done to my TA23. Will include photos when done, for all to see.
So ventilated brakes here they come.
Re: Differences between RA60 & RA65 struts?? Any takers Wed, 18 September 2002 23:26 Go to previous messageGo to next message
Are you aware that using RA6x struts in a TA23/RA23 will screw up your camber? You'll actually end up with positive camber if you don't take steps to fix it (eg longer control arms).
CEL023
Newy
icon12.gif  Re: Differences between RA60 & RA65 struts?? Any takers Fri, 20 September 2002 01:19 Go to previous messageGo to next message
So Norbie, ive just read the other thread.
You used to have a RA23?
So by how much do you think the camber will be out by?
And the mx65 control arms are longer, could this be the answer to the camber problem? Will there be any issues there with the fitment of those?
I have to upgrade soon as 1 of the current struts has positive camber and is smoothing 1 of my 17s on the outer edge.
As you probably aware 17s arnt cheap. So i will be fitting another set of 15s back onto the Cel this weekend, for now.
Will probably proceed with purchase of the RA65 struts and brakes & compare.
Is this the case for just the 23s or will it affect the 22s as well. Cause a friend whose already done it, doesnt use his cel much since the upgrade as his using a company car.
Thanks for the insight though.
Re: Differences between RA60 & RA65 struts?? Any takers Fri, 20 September 2002 07:57 Go to previous messageGo to next message
I still have my RA23. I'm pretty sure there are pics of it on my web site with the MA61 struts installed, and the positive camber is easily seen with the naked eye.
MS65 control arms are worth a shot if they're a bit longer. A friend of mine used Sigma control arms in his T18 when he installed RA60 struts, and that worked OK for him. The problem with this is the longer control arms also make the front track wider, which can introduce clearance problems with the front wheels (it's also illegal). It was very obvious on the T18, although it looked pretty tough! Smile
CEL023
Newy
icon7.gif  Re: Differences between RA60 & RA65 struts?? Any takers Fri, 20 September 2002 10:24 Go to previous messageGo to next message
So let me get this right.
The camber is out if RA60/5 control arms are used or the standard TA23 arms?
Cause I plan on using the TA23 arms as my friend has with his TA22. His appears to be fine.
Re: Differences between RA60 & RA65 struts?? Any takers Fri, 20 September 2002 15:28 Go to previous messageGo to next message
TA23/RA23 arms will get you crazy camber angles. I find it hard to believe it would be much different in a TA22. Have you actually measured the camber in that?
CEL023
Newy
icon7.gif  Re: Differences between RA60 & RA65 struts?? Any takers Wed, 25 September 2002 09:14 Go to previous message
Still yet to be done.
Previous Topic:4AGE reco head
Next Topic:Engine Convert ST141
Current Time: Sat Nov 21 15:02:53 UTC 2026
Total time taken to generate the page: 0.010649919509888 seconds
