Toymods » Tech & Conversions » Diff ratio in standard G series Torsen?
MR 1JZ
Diff ratio in standard G series Torsen? Mon, 16 August 2004 10:02 Go to next message
Does anyone know what the final drive ratio is on a Standard G series Torsen Diff?
I am also considering getting rid of it when the 1JZ goes in becuase progressive LSD shites me right off, i.e. One wheel, then two, then one, then two, etc,etc...
I dont really want to change the diff housing, so what centre would be a suitable replacement?
Re: Diff ratio in standard G series Torsen? Mon, 16 August 2004 11:45 Go to previous messageGo to next message
What do you mean propressive LSD? If you have a clutch pack LSD it should just spin both wheels unless its f**ked. Are you sure you even have an LSD, most I've seen GZ20's dont.
Jonny2TG
Tasmania
Re: Diff ratio in standard G series Torsen? Mon, 16 August 2004 13:45 Go to previous messageGo to next message
If you want a G series clutch plate LSD, get a center from a 4wd HiLux, or MA70 Supra. You should be able to keep your crown wheel and pinion, just swap the very center diff parts.
I guess the TorSen diff was ment more for snow and safety on wet roads. Not so good for sport. Interesting.
Re: Diff ratio in standard G series Torsen? Mon, 16 August 2004 23:24 Go to previous messageGo to next message
My torsen LSD doesn't behave like that at all. In fact it behaves like a really tight clutch LSD. Are you sure you have a torsen?
lumpy
Adelaide, SA
Re: Diff ratio in standard G series Torsen? Mon, 16 August 2004 23:50 Go to previous messageGo to next message
MR 1GGTE wrote on Mon, 16 August 2004 19:32
Thats sounds more like a clutch pack LSD that is getting a bit tired. You can get the clutches re-tightened/shimmed on these.
MR 1JZ
Re: Diff ratio in standard G series Torsen? Tue, 17 August 2004 03:07 Go to previous messageGo to next message
Apparently my axel code matches that of a factory fitted torsen LSD...
Might have to look into getting it tightended then...
Gear ratios tho?
Re: Diff ratio in standard G series Torsen? Tue, 17 August 2004 03:33 Go to previous messageGo to next message
Diff ratio is determined by the crownwheel and pinion, NOT the diff centre. It's a totally separate issue.
Re: Diff ratio in standard G series Torsen? Tue, 17 August 2004 06:19 Go to previous messageGo to next message
Don't always believe the plate, get underneath and check out the car for yourself - many times things get swapped/changed long before you even see the car.
E30-323ti
Re: Diff ratio in standard G series Torsen? Wed, 18 August 2004 06:57 Go to previous messageGo to next message
I was under the impression the JZA70 was the only car to come equiped with a "G" series TORSEN (G**9 would be on the build plate)
As the Soarers JZZ30/Supras JZA80 have a "A" or "B" series diff.
Re: Diff ratio in standard G series Torsen? Wed, 18 August 2004 07:13 Go to previous messageGo to next message
You're correct about the JZZ30 Soarer, but it's possible the earlier Soarers (eg MZ20) were available with a G series torsen centre. I've never actually seen one, but Toyota are good at mix'n'matching parts.
AFAIK if your Soarer was originally fitted with a torsen, the axle code on the build plate should read "Gxx9". A clutch LSD will be Gxx5 and a single-spinner (most common) will be Gxx4.
Bugman
Re: Diff ratio in standard G series Torsen? Wed, 18 August 2004 22:17 Go to previous messageGo to next message
whats your trans code, as far as I knew only jza70s had torsens.
MR 1JZ
Re: Diff ratio in standard G series Torsen? Thu, 19 August 2004 10:42 Go to previous messageGo to next message
Im going outside to check my trans code now, if i dont come back avenge my death...Very Happy
MR 1JZ
Re: Diff ratio in standard G series Torsen? Thu, 19 August 2004 10:50 Go to previous messageGo to next message
ok the axel code is G254? what does that mean???
Re: Diff ratio in standard G series Torsen? Thu, 19 August 2004 11:36 Go to previous messageGo to next message
That code means you have a 4.556 non-LSD diff, just as most GZ20's have, and the reason you're bitching about your LSD not working properly Laughing
Re: Diff ratio in standard G series Torsen? Thu, 19 August 2004 22:19 Go to previous messageGo to next message
Laughing
lumpy
Adelaide, SA
Re: Diff ratio in standard G series Torsen? Thu, 19 August 2004 22:57 Go to previous messageGo to next message
justcallmefrank wrote on Thu, 19 August 2004 21:06
It means once the 1jz is in you'll be pulling big single spinner burnouts everywhere you go Laughing
4.556:1 will make for some terrific acceleration off the line, if you ever get traction.
Bugman
Re: Diff ratio in standard G series Torsen? Fri, 20 August 2004 00:17 Go to previous messageGo to next message
and ga70s manuals were fitted with that ratio but with the 5 on the end. LSD
Re: Diff ratio in standard G series Torsen? Fri, 20 August 2004 01:11 Go to previous messageGo to next message
LSD was optional on the GA70's... they more often come with open diffs.
Bugman
Re: Diff ratio in standard G series Torsen? Fri, 20 August 2004 03:00 Go to previous messageGo to next message
even the manuals?
MR 1JZ
Re: Diff ratio in standard G series Torsen? Fri, 20 August 2004 04:12 Go to previous messageGo to next message
Then my diff is well and truly fuct...
I chucked some chemi weld in the 1GGTE last night so I could go for one last thrash, went down to the local park and ripped a fat burnout in the carpark, two wheels, two lines, lots of smoke... Very Happy
Open wheeler diffs become fucked when they start doing LSD burnouts
Even i know this...
Right this thread will be changed to what diff that is LSD will fit into my diff housing?
Re: Diff ratio in standard G series Torsen? Fri, 20 August 2004 04:15 Go to previous messageGo to next message
JZA70 Torsen or MA70 clutch-LSD should both fit, but it might be easier to swap the whole thing over, cheaper too, still requires a removal and install.
MR 1JZ
Re: Diff ratio in standard G series Torsen? Fri, 20 August 2004 04:33 Go to previous messageGo to next message
yes but the brakes and shit are different on my car than a supra...
What is the differences between the clutch LSD and the Torsen??
Re: Diff ratio in standard G series Torsen? Fri, 20 August 2004 04:39 Go to previous messageGo to next message
MR 1GGTE wrote on Fri, 20 August 2004 14:33
WTF? He's talking about swapping the diff, not the brakes.
http://www.google.com
MR 1JZ
Re: Diff ratio in standard G series Torsen? Fri, 20 August 2004 04:47 Go to previous messageGo to next message
Norbie wrote on Fri, 20 August 2004 14:09
I thought he meant swap the entire diff over, uni joints and all??
Then again I forgot about the IRS for a second there...
MR 1JZ
Oh yeah dont believe in google, im just too lazy... Very Happy
Bugman
Re: Diff ratio in standard G series Torsen? Fri, 20 August 2004 05:47 Go to previous messageGo to next message
howthingswork.com explains a torsen too
Re: Diff ratio in standard G series Torsen? Fri, 20 August 2004 06:14 Go to previous messageGo to next message
MR 1GGTE wrote on Fri, 20 August 2004 14:47
Uni joints? Have you ever looked under your car??
MR 1JZ
Re: Diff ratio in standard G series Torsen? Fri, 20 August 2004 06:53 Go to previous message
Norbie wrote on Fri, 20 August 2004 15:44
Obviously not well enough to know what i am talking about...Razz
I will shut up now...
Previous Topic:ST205 Standard Wheel Offset?
Next Topic:1G Flywheel Differences
Current Time: Tue Oct 20 22:35:00 UTC 2026
Total time taken to generate the page: 0.11463904380798 seconds
