Toymods » Tech & Conversions » 4K with 2 speed toyoglide :D rocks!!
4K with 2 speed toyoglide :D rocks!! Mon, 16 August 2004 11:54 Go to next message
hey all,
fair enough most of you don't even know what a toyoglide actually is but...
spent the weekend taking out the K motor from my sisters '67 KE10, and replacing it with a 4K (small port = 25mm!!).
and what a difference 12mm of stroke (and 200cc) can make!!
before the car was 'a bit of a slug'.. hills even in low were pretty sucky..
now with the 1300, hills are no issue, car is very driveable, and happily cruises at 100km/hr. will hold low until over 90km/hr if desired! kickdown during wet corners is 'much more interesting' than previously Wink (15psi in tires also helps Very Happy )
anyway, i was pretty sceptical before about the 2 speed, suggesting that the 3 speed traumatic was a better option, but i can safely say that i would be happy with a 4K'd 2 speed as a daily driver (if it was a KE10 Wink ).
just thought i'd get this out in the open Laughing
Jonny2TG
Tasmania
Re: 4K with 2 speed toyoglide :D rocks!! Mon, 16 August 2004 13:39 Go to previous messageGo to next message
I worked on a 1966 RT40 Corona last week. It had the 2R motor and Toyoglide. I am guessing the 2R is about 1600cc. Were all Toyoglides the same unit or were they different sizes to match the motor?
My KE55 originaly had a 4K with Holden Trimatic. It was ok I guess. Nothing special, but it worked.
Bugman
Re: 4K with 2 speed toyoglide :D rocks!! Mon, 16 August 2004 14:02 Go to previous messageGo to next message
whats the official weight of the corollas up till ke35?
Re: 4K with 2 speed toyoglide :D rocks!! Mon, 16 August 2004 16:40 Go to previous messageGo to next message
heya Jonny,
i believe there are different ones. i have a toyota factory manual for a 2 speed toyoglide, but it's larger than the KE10 one, and i think it's the R series.. i'll have a closer look at some stage.
bugman.
KE10/11 - 720kg
KE15/17 - 730-740kg
KE20, approx 750-780kg
cenithx
west sydney
Re: 4K with 2 speed toyoglide :D rocks!! Mon, 16 August 2004 18:04 Go to previous messageGo to next message
I got the Toyoglide 2 speed in my ke30 Very Happy about to be replaced with the 4-speed sitting on the garage floor when I figure out how..
2 speed rocks.. there's just something way cool (in an uncool and funny way) about having only 2 gears Razz
bassy
Re: 4K with 2 speed toyoglide :D rocks!! Tue, 17 August 2004 04:29 Go to previous messageGo to next message
i have a ke10 with a 4k toyoglyde. its good for just cruising but i hate the fact i dont have that much control over it. thats y iam changing to a 5k high cam with a five speed this wednesday. should b a tad better.
Re: 4K with 2 speed toyoglide :D rocks!! Tue, 17 August 2004 05:17 Go to previous messageGo to next message
what do you mean not much control?? by adjusting the kickdown a little, this has very good characteristics.. kicks down at the right time depending on throttle position, and stays in first if you want it to...
you have an OHC 5K? if not, could you please explain what this high cam is?
Re: 4K with 2 speed toyoglide :D rocks!! Tue, 17 August 2004 05:41 Go to previous messageGo to next message
Surely you've seen stickers in older Toyota's proudly advertising "HiCam" (or something like that)? A bit like the "Super Responsive" sticker in the engine bay of my MA61... quite amusing when applied to a 5M-E. It's marketing wank basically.
Re: 4K with 2 speed toyoglide :D rocks!! Tue, 17 August 2004 06:09 Go to previous messageGo to next message
i know what "HiCam" is, but many people seem to be convinced their is a difference (even some toyota ex-employees i know) but i am yet to be convinced..
what it seems to mean in practive is "highly restricted", ie smaller intake ports (down to 25mm vs 27 or 30mm), vac operated secondaries, more restrictive air cleaner etc.
mmm "super responsive"... i don't think that applies to any K motor Wink
Re: 4K with 2 speed toyoglide :D rocks!! Tue, 17 August 2004 07:25 Go to previous messageGo to next message
I had an old MS40 with a 2 speed Toyoglide behind the M. It was a hoot. I'm sure it would be bigger than a K series Toyoglide. I kept the badge so I could put it on my 1UZ powered auto wagon.
ed_ma61
Lost in the K hole
Re: 4K with 2 speed toyoglide :D rocks!! Tue, 17 August 2004 07:29 Go to previous messageGo to next message
i also have a minter badge if you want it stewy Very Happy
Bugman
Re: 4K with 2 speed toyoglide :D rocks!! Tue, 17 August 2004 12:53 Go to previous messageGo to next message
my 22r-e was super responsive too
damn gay 80s shite.
Bugman
Re: 4K with 2 speed toyoglide :D rocks!! Tue, 17 August 2004 13:20 Go to previous messageGo to next message
also found a site saying the ke20 is 830 kg...
I might have to search again.. minimum of 800kg for a 1g.. would like to get a car to put away and do something major to.
Bugman
Re: 4K with 2 speed toyoglide :D rocks!! Tue, 17 August 2004 13:24 Go to previous messageGo to next message
Hullo Benjamin,
According to my workshop manual these are the weights :
KE 30 two door : 820 kilogram
KE 30 four door : 830 kilogram
KE 35 : 860 kilogram
KE 35 SL and SR 870 kilogram
add 15 kilogram each time for automatic transmission cars.
anyone confirm this?
Re: 4K with 2 speed toyoglide :D rocks!! Tue, 17 August 2004 13:52 Go to previous messageGo to next message
according to code of practice for light vehicle mods, the "typical weight" to be used for figuring out mods for vehicles is:
corolla KE11 1200 auto sedan = 746kg
corolla KE20 1200 auto sedan = 778kg
corolla KE25 1200 coupe = 756kg
KE35 auto coupe = 864kg
KE30 auto sedan = 891kg
KE36 panel van = 841kg.
these may not be accurate, but are used by engineers as guidelines. for my blueslip for my 15, i had to get weighbridge printout as the KE15 was not on his books.
Re: 4K with 2 speed toyoglide :D rocks!! Tue, 17 August 2004 14:00 Go to previous messageGo to next message
HiCam was a term used to describe the "relative" positioning of the camshaft in the K motors - since it was a little higher than most pushrod engines, they called it a HiCam. Or so i'm told?
Hey man, dont knock the Super Responsive!
Pimp Bot has both HiCam and SuperResponsive properties!!
Jonny2TG
Tasmania
Re: 4K with 2 speed toyoglide :D rocks!! Tue, 17 August 2004 14:11 Go to previous messageGo to next message
THE WITZL: Are you joking or do you still not get it. "HiCam" does not mean anything. The cam is not higher!
Tonight, my TE37 is about 940kg. 530kg front, 410kg rear.
Re: 4K with 2 speed toyoglide :D rocks!! Tue, 17 August 2004 22:39 Go to previous messageGo to next message
My KE70 has got 'hicam' on one side, and '1.6' on the other. Been meaning to swap these both for Royal Saloon sometime though!
Re: 4K with 2 speed toyoglide :D rocks!! Wed, 18 August 2004 00:51 Go to previous message
YOU STEAL MY IDEA SHIN!!! Mad Although i'm going for "Super Saloon", along with "sprinter XX grande", and maybe something else.
Jonny - i do realise it means nothing. My point was that it was a half baked marketing ploy, based on the relatively USELESS fact that the cam was just a little higher in the block than most other manufacturers pushrod engines. I really made no difference to performance and means nothing. Very Happy
But it sounds cool!
Previous Topic:TA22 auto to manual swap?
Next Topic:Removing W5? from 4AGE while still in the car
Current Time: Fri Nov 20 20:56:39 UTC 2026
Total time taken to generate the page: 0.0072460174560547 seconds
