Classifieds » Miscellaneous » 2T-GEU plus extras
Dominic
Perth,western australia
2T-GEU plus extras Tue, 17 August 2004 01:10 Go to next message
here it is:
complete 2T-GEU motor,loom,ecu and gearbox
has K&N airfilter,4 into 1 extractors,head was fully recond less than 2 yrs ago, water pump and timing gear done at the same time:$1000
bosch high pressure fuel pump,Low pressure lift pump and surge tank: $300(will seperate these items)
3t-c complete but in parts $120
3T-GTEU injectors recently serviced: $100
4A-GE injectrors $50
2T-G new conrod bearings: $40
2T-G race cams 298 deg duration,10.414 lift $400
2.5 inch exaust to suit RA28/23 less than 6months old $300
will ship interstate at buyers expense.and i can get photos of these parts as well.
cheers,
Dom
http://forums.toymods.org.au/index.php?t=getfile&id=6146
Attachment: DCP_6006.jpg
(Size: 84.49KB, Downloaded 297 time(s))
[Updated on: Tue, 24 August 2004 06:21]
Swampy
Adelaide, SA
Re: 2T-GEU plus extras Tue, 17 August 2004 01:49 Go to previous messageGo to next message
pm sent
7mgtema71
Re: 2T-GEU plus extras Tue, 17 August 2004 04:13 Go to previous messageGo to next message
What spec's do you have on those cams? Duration, lift, usage, condition, anything else? Cheers
steve-O
wollongong
Re: 2T-GEU plus extras Tue, 17 August 2004 07:10 Go to previous messageGo to next message
i might be interested in the conrod bearings
Dominic
Re: 2T-GEU plus extras Tue, 17 August 2004 08:54 Go to previous messageGo to next message
this is what is on the tag that came with them:
lift at lobe: .410" in/ex
ex opens @75deg closes at 43deg
in opens @45deg closes at 73deg
inlet valve lift @TDC on teh overlap .168" ex .147"
i think if you add the 2 degree values together and take that away from 360 that will give you the duration value but im not to sure.
as far as i know these cams have never been used and there condition is great.
cheers,
Dom
[Updated on: Tue, 17 August 2004 08:56]
Dominic
Re: 2T-GEU plus extras Tue, 17 August 2004 08:56 Go to previous messageGo to next message
if i sent them in a coloured box of your choice would it make you more interested??
Wink
cheers,
Dom
dave_ke30
sydney, the shire
Re: 2T-GEU plus extras Tue, 17 August 2004 09:47 Go to previous messageGo to next message
hey interested in 2gteu.... in good condition? PM sent
Dominic
Re: 2T-GEU plus extras Wed, 18 August 2004 08:15 Go to previous messageGo to next message
more pics where that one came from.
Dom
people100
Rocklea qld
Re: 2T-GEU plus extras Wed, 18 August 2004 10:14 Go to previous messageGo to next message
how many cc's are the 3tgteu injecters?
TA22
Re: 2T-GEU plus extras Thu, 19 August 2004 00:45 Go to previous messageGo to next message
how bigs the surge tank, and which model fuel pumps?
Dominic
Re: 2T-GEU plus extras Thu, 19 August 2004 01:18 Go to previous messageGo to next message
from what i have found on this site(toymods).the 3tgte injectors flow about 295cc a minute.
thats information that i found by searching this website.
cheers,
Dom
Dominic
Re: 2T-GEU plus extras Thu, 19 August 2004 01:25 Go to previous messageGo to next message
im preety sure that the surge tank holds 2lts.its 100mm high and wide 200mm long(its box like,not round).its has 2 inlets/outlets at each end.ill post a photo of it soon cos i think youll want to see the shape of it.
i remember that the lift pump is a faucet and the HP pump is a bosch but ill have to get back to you on the details cos i cant remember off the top of my head.
cheers,
Dom
steve-O
wollongong
Re: 2T-GEU plus extras Thu, 19 August 2004 13:31 Go to previous messageGo to next message
i've just gotta try and get my hands on a micrometer to measure my crank. i wish i knew someone who had one...
TA22
Re: 2T-GEU plus extras Thu, 19 August 2004 13:33 Go to previous messageGo to next message
theyre cheap
like 30 - 40 dollars
Dominic
Re: 2T-GEU plus extras Fri, 20 August 2004 01:19 Go to previous messageGo to next message
sorry but i cant find any of my info that i had on the fuel pumps.
i can do flow tests this weekend and let you know the results.
cheers,
dom
takahashi
Outer Sydney
Re: 2T-GEU plus extras Sun, 22 August 2004 04:43 Go to previous messageGo to next message
hey mate, hows the compression like on the 2tgeu?
jesseT18
Castle Hill, Sydney
Re: 2T-GEU plus extras Sun, 22 August 2004 08:58 Go to previous messageGo to next message
got a electronic dizzy for a 2tg?
Dominic
Re: 2T-GEU plus extras Sun, 22 August 2004 11:55 Go to previous messageGo to next message
last time i did it was preety good across all cylinders.
i cant remember exact values but i have a compression tester so ill check it out tommorrow and give you some results.
cheers.
Dom
Dominic
Re: 2T-GEU plus extras Sun, 22 August 2004 11:57 Go to previous messageGo to next message
the only one i have is still on my 2tgeu.
magnetic pick up style.
sorry not parting out engine at this point.
cheers.
Dom
Dominic
Re: 2T-GEU plus extras Tue, 24 August 2004 06:12 Go to previous messageGo to next message
hiya,
its been raining all weekend over here,but i managed to get a clear patch today and get some results for ya.
cyl 1 130 lb/in(sq) 9 kg/cm(sq)
cyl 2 135 9.5
cyl 3 135 9.5
cyl 4 140 10
the engine was at operating temp when i did the test.
cheers,
dom
Dominic
Re: 2T-GEU plus extras Tue, 24 August 2004 06:17 Go to previous messageGo to next message
bump
Dom
[Updated on: Thu, 26 August 2004 07:51]
Dominic
Re: 2T-GEU plus extras Fri, 27 August 2004 06:26 Go to previous message
just bump it.
Dom
Previous Topic:3SGTE complete engine suit rebuild
Next Topic:16" 5x114.3 Rims for sale
Current Time: Wed Oct 14 09:49:56 UTC 2026
Total time taken to generate the page: 0.084352016448975 seconds
