Toymods » Tech & Conversions » Pulling head off AE92 GZE without removing Engine
takai
Pulling head off AE92 GZE without removing Engine Tue, 17 August 2004 03:28 Go to next message
Has anyone done this. I cant see any way its realistically possible. The supercharger is bolted to both the intake manifold and the block, and there is extremely little room on the back (firewall) to remove the charger.
Im a bit stuck, i guess ill take it into my old work and get them to pull the engine out, unless someone else has a brilliant idea in the next hour or so.
._T_.
Re: Pulling head off AE92 GZE without removing Engine Tue, 17 August 2004 03:42 Go to previous messageGo to next message
yeah you can do it - although it is probably not much more work to pull the whole motor/box - & easier to work on. you will have to remove the bonnet
T
takai
Re: Pulling head off AE92 GZE without removing Engine Tue, 17 August 2004 13:35 Go to previous message
Just thought i would give a definate yes.
Its actually quite easy once you think abou it.
The hardest bit is getting the supercharger outlet/abv off, after that its all easy.
Previous Topic:3TGTE TA22...
Next Topic:W58, 225 or 235 mm cover??
Current Time: Fri Nov 20 18:13:36 UTC 2026
Total time taken to generate the page: 0.0041751861572266 seconds
