Toymods » Tech & Conversions » quick one... signs of blown head gasket...
RA40Celica
Hobart
  chris_rg@jabber.org
quick one... signs of blown head gasket... Tue, 17 August 2004 06:21 Go to next message
Does this seem right..
-Losing coolant
-Bubbles in coolant when running
-Misfire on starting (mostly cold)
all points to blown head gasket????
anything else it could be?
Chris
[Updated on: Tue, 17 August 2004 06:22]
Re: quick one... signs of blown head gasket... Tue, 17 August 2004 06:27 Go to previous messageGo to next message
I'd be pretty confident thats a headgasket!
ra23celica
Re: quick one... signs of blown head gasket... Tue, 17 August 2004 06:50 Go to previous messageGo to next message
Have you got mocha coffee chocolate foam up high on the inside of your 710 (oil) filler cap ?
Mitch.
RA40Celica
Hobart
  chris_rg@jabber.org
Re: quick one... signs of blown head gasket... Tue, 17 August 2004 07:11 Go to previous messageGo to next message
ra23celica wrote on Tue, 17 August 2004 16:50
Mitch.
nope, none of that.
if there was water in the oil, would i see it on the dip stick, or will i need to drain it to see?
ra23celica
Re: quick one... signs of blown head gasket... Tue, 17 August 2004 07:18 Go to previous messageGo to next message
Hmm, OK.
If there is water in the oil, as the oil heats up the water separates from it and the resulting brown oil mist collects inside your oil fill cap as a 'mocha' foam.
You won't necessarily see any water on the dip-stick.
You might be losing water elsewhere, have you checked for tell tale coolant stains (green / red ) around the engine ?
TecEVO
Switzerland
Re: quick one... signs of blown head gasket... Tue, 17 August 2004 08:10 Go to previous messageGo to next message
Was just working on a friends car, It was loosing water and had fine bubbles (0.2mm diameter) constantly appearing when the radiator cap was off. I was worried about the head gasket or a cracked head, but I found a very small leak in the radiator, Just replaced the radiator, seems to have fixed it, no more fine bubbles, will know more in a day or so, see if it still looses water.
So you might be luck but then again it did not have any misfire
RA40Celica
Hobart
  chris_rg@jabber.org
Re: quick one... signs of blown head gasket... Tue, 17 August 2004 12:10 Go to previous messageGo to next message
The filler cap doesn't really have anywhere 'in' it that foam can build up. The engine is 18rg.
The bubbles im getting are quite large. If you fill the radiator to the neck, then run it for while with the cap off bubbles start coming. Big enough to spill coolant as they 'burp'.
im pretty sure its time for a head gasket....
V8_MA61
Re: quick one... signs of blown head gasket... Tue, 17 August 2004 13:31 Go to previous messageGo to next message
those bubbles should go away if you leave the car run. it means there is air in the system. It happens whenever someone replaces coolant. It means you should "burp" the system.
if you could see water in the oil, you will also be able to see oil in the water.
id do some more research before concluding its a BHG!
earlyrolla
Re: quick one... signs of blown head gasket... Tue, 17 August 2004 13:54 Go to previous messageGo to next message
Head gaskets tend to blow between cylinders. The simplest way is to do a compression test.
You can loose water into the cylinder(s). I have seen this on a falcon 6cyl motor.
You can expect bubbles in the coolant once the engine warms up (thermostat opened) as the water is circulating through out the engine.
If water gets into the oil, the oil will generally go a milky colour. If the engine has sat for a long time, only then will the oil and water separate to an extent that both are visible on the dip stick.
MR 1JZ
Re: quick one... signs of blown head gasket... Tue, 17 August 2004 15:35 Go to previous messageGo to next message
my engine bay becomes a steam room when i go around the block, is this due to a head gasket blwoing on the outer side of the head and water seeping through or is this a blown heater hose or something???
RA40Celica
Hobart
  chris_rg@jabber.org
Re: quick one... signs of blown head gasket... Tue, 17 August 2004 23:25 Go to previous messageGo to next message
V8_MA61 wrote on Tue, 17 August 2004 23:31
they wont go away if they're coming from the combustion chamber Smile
and yes ive let it run for a long time, watching bubbles come out... they dont go away.
Yeh i might see if i can get a compression tester.
thanks all, for your input.
joecoolmk2
Re: quick one... signs of blown head gasket... Tue, 17 August 2004 23:38 Go to previous messageGo to next message
MR 1ggte, sounds more like a leak in your coolant system. my mx23 had a couple of holes in the radiator. it makes the engine over heat and boil the coolant, making lots of steam, and you'll lose all of your coolant. see if you can find any water stains anywhere in your engine bay. that'll lead you to the source of the leak.
MR 1JZ
Re: quick one... signs of blown head gasket... Wed, 18 August 2004 01:53 Go to previous messageGo to next message
Oh i knopw my motor has a hole in it, because wheneve I try to put water in it comes straight out, but one night it just started to steam up and shit, I was wondering if that could be fixed temoraroily till my motor arrives from Japan?
joecoolmk2
Re: quick one... signs of blown head gasket... Wed, 18 August 2004 02:15 Go to previous messageGo to next message
how quick do you lose the water? if it isn't in the blink of an eye, you could try using an engine/radiator flush then a bottle of seal-up(chemiweld). that is if the time it takes to do it and the length of time you only need the engine for is worth it?
MR 1JZ
Re: quick one... signs of blown head gasket... Wed, 18 August 2004 02:36 Go to previous messageGo to next message
See the thing is that the block and radiator has already been flushed, thats how i found out there were holes in the block becuase the gunk that was in there before was sealing up the holes, my head is cracked and i am waiting on a 1JZ from japan which gets here in about a week, but i really wanted to tkae it out and thrash it one last time....
But this chemiweld stuff sounds the goods, where can i get some and how much does it cost???
RA40Celica
Hobart
  chris_rg@jabber.org
Re: quick one... signs of blown head gasket... Wed, 18 August 2004 02:49 Go to previous messageGo to next message
did a compression test... can't deny it now.
1: 140 psi
2: 140 psi
3: 160 psi
4: 160 psi
also... number 1 plug looked a bit oily...
so i know what im doing this weekend... Smile
hopefully i can get the gaskets by then
Chris
YelloRolla
On your mum!
Re: quick one... signs of blown head gasket... Wed, 18 August 2004 07:35 Go to previous messageGo to next message
I have blown a couple of head gaskets hwere the cylinder pressure leaks into the coolant when engine is running. A compression test will not detect such a minor leak as it requires high cylinder pressure to induce the leak.
No oil into water and no water into oil - some exhaust fumes in the water tho.
The pressure created blows water out of the overflow - hence coolant loss.
Re: quick one... signs of blown head gasket... Wed, 18 August 2004 22:15 Go to previous message
Yup, that's exactly what happened to my 18R-G. A couple of full-throttle blats and the radiator was empty!
Previous Topic:what kinda engine?
Next Topic:Standard stock aussie spec Sprinter. How much does it wiegh?
Current Time: Mon Oct 26 13:46:34 UTC 2026
Total time taken to generate the page: 0.075249910354614 seconds
