Toymods » Tech & Conversions » 4AF Alternator onto a a 4AC?
ToyCam
4AF Alternator onto a a 4AC? Tue, 17 August 2004 11:40 Go to next message
My alternator is stuffed and i've been reading that the standard 4ac alt. is pretty ordinary, even when in good condition.
So is it possible if you swap the mounting brackets and pulley?
Steve
[Updated on: Thu, 26 August 2004 10:21]
ae86drift
sydney.au
Re: 4AG Alternator onto a a 4AC? Tue, 17 August 2004 12:40 Go to previous messageGo to next message
from memory i dont think so
anyone confirm?
Hunty
Re: 4AG Alternator onto a a 4AC? Tue, 17 August 2004 12:54 Go to previous messageGo to next message
yep belts are diff, from what i can see on mine
ToyCam
Re: 4AG Alternator onto a a 4AC? Wed, 18 August 2004 08:30 Go to previous messageGo to next message
That why i said change the pulley over from the 4ac onto the 4ag alternator, should be able to use the same belt then maybe??
Steve
cri_ag
northern beaches
Re: 4AG Alternator onto a a 4AC? Wed, 18 August 2004 11:41 Go to previous messageGo to next message
my sprinter seems to run the fwd water pump, alternator and multi-v belt as oposed to the stadard single v and the alternator that i have on looks very similar to a 4age one. only problem is the waterpump outlet is right in the way of the alternator (it hits it).
Hunty
Re: 4AG Alternator onto a a 4AC? Wed, 18 August 2004 12:54 Go to previous messageGo to next message
ToyCam wrote on Wed, 18 August 2004 18:00
Steve
hmmmmm good point, i never went as far into it as that, effort factor was too high Razz plus my alternator was working fine i had two 1000W amps running 2 12' subs and a set of 6x9's and i used to have that runing all the time the only time i notice a problem wsa when i had the headlights on my foot on teh brakes and whn the bass hit the head lights dimmed a bit and teh revs droped about 100-200 rpm idle was at 900rpm normally but give it a bit of throttle say 1500rpm and it was sweet as, i havent changed the battery in it since i bought it 3 years ago now, well i got a new battery for teh 4age just to be on the safe side . hey u wanna buy mine??? Wink my 4ac's been outta the car for about a month now and was running sweet as before hand its done 178,000 k's PM me if ya want
ToyCam
Re: 4AG Alternator onto a a 4AC? Thu, 19 August 2004 01:06 Go to previous messageGo to next message
Hmmm, I guess i'm just going to have to get one from the wrecker and go by trial and error. I was thinking maybe of even a 4afe, if they exist, from a standard rolla...
I'll post up here when i find out..
Hunty: Thanks for the offer, but i already got a 4ac sitting in my garage Razz
Check this link to see it with nice fat holes either side Smile
http://forums.toymods.org.au/index.php?t=msg&t h=39152&rid=2426&S=76ad29b674408d150d5cd8a 51899d640
Steve
RobertoX
Re: 4AG Alternator onto a a 4AC? Thu, 19 August 2004 02:10 Go to previous messageGo to next message
If it can fit, you should remember that you have to change the wiring slightly. 4AG alternator uses an internal regulator wheras the 4AC has the external one. Its not hard or anything, just not a direct plug 'n' play
ToyCam
Re: 4AG Alternator onto a a 4AC? Thu, 19 August 2004 03:06 Go to previous messageGo to next message
Yeah, I was thinking about that.
When did they bring in internal regs and can you just bypass the original reg??
Wouldn't it be nice if all parts were universal Razz
Steve
RobertoX
Re: 4AG Alternator onto a a 4AC? Thu, 19 August 2004 05:26 Go to previous messageGo to next message
Yep, you just bypass the external regulator. As far as I remember There are 2 wires that need to go from the chassis loom to the alternator (it has a 3 pin plug, the 3rd one comes from the power out).
Oh yeah, 4ages have the alt on RHS(mine does anyway) wheras the 4AC has it on LHS... I dont think an alternator will fit among all of that crap on the inlet/outlet side of a 4ac. Also fitting the c pulley to the ge alternator and using ge brackets will very likely skew the belt ie. the pulleys will not line up.
ToyCam
Re: 4AG Alternator onto a a 4AC? Thu, 19 August 2004 07:09 Go to previous messageGo to next message
Is the 4ag alt on a swing type hinge, ie. a bolt through two holes on the bottom?? if so, can't you use the c bracket, with a bit of lateral thinking and persuasion( ie. a hammer Razz ) and fit it on the LHS like standard.
[Updated on: Thu, 19 August 2004 07:11]
cri_ag
northern beaches
Re: 4AG Alternator onto a a 4AC? Thu, 19 August 2004 07:44 Go to previous messageGo to next message
my 4ac alt is under the intake manifold
RobertoX
Re: 4AG Alternator onto a a 4AC? Thu, 19 August 2004 08:42 Go to previous messageGo to next message
cri_ag wrote on Thu, 19 August 2004 17:44
There you go then... Does it have a wide belt with lots of grooves? or a single v-belt? Could be from a corolla?
[Updated on: Thu, 19 August 2004 08:42]
ToyCam
Re: 4AG Alternator onto a a 4AC? Thu, 19 August 2004 08:45 Go to previous messageGo to next message
Just curious, i know the 4ag is also set up like this, but has anyone had a problem with water getting into it at all, cos its mounted lower?
cri_ag
northern beaches
Re: 4AG Alternator onto a a 4AC? Thu, 19 August 2004 09:00 Go to previous messageGo to next message
as stated above it has a multi-v belt and the water outlet is just above the alternator. i think the entire setup is from a fwd but i still have an engine driven fan. where would the external regulator normaly sit? i dont think i have one anymore.
Flogbag
Sydney (Campbelltown...!)
Re: 4AG Alternator onto a a 4AC? Thu, 19 August 2004 11:48 Go to previous messageGo to next message
i have a 4age single v altenator with internal regulator pretty sure it came off a jdm ae86 4age
dont know if itll fit in place of a 4ac one though
Flogbag
Re: 4AG Alternator onto a a 4AC? Thu, 19 August 2004 11:50 Go to previous messageGo to next message
ToyCam
Re: 4AG Alternator onto a a 4AC? Thu, 19 August 2004 12:22 Go to previous messageGo to next message
Original reg sits just above the coil, behind the battery. Little metal box with 4 wires, i think, going into it.
ToyCam
Re: 4AG Alternator onto a a 4AC? Thu, 26 August 2004 10:00 Go to previous message
OK, just got a an alternator off a 4afe. Brackets are gonna need a bit of manipulating (read: angle grinding Twisted Evil ), but thats the easy bit.
Any idea how to get the pully bolt off without a rattle gun??
And does anyone know how to bypass an external regulator...or would i be better off getting an auto electrician?
CHeers
Steve
Previous Topic:Thermo fan on a 3sgte gen II
Next Topic:Rattlegun won't take flywheel off :( what can I do?
Current Time: Wed Sep 9 00:32:15 UTC 2026
Total time taken to generate the page: 0.012665987014771 seconds
