Toymods » Tech & Conversions » what size jets
Mr DOHC
what size jets Tue, 17 August 2004 12:20 Go to next message
18RG, 282/282 deg cams, 12mm {465"} lift, big valves, about 9 to 1, what size jets in the stock solex carbs, i have 200 up top and 160 down below
Jonny2TG
Tasmania
Re: what size jets Tue, 17 August 2004 13:48 Go to previous messageGo to next message
I am wanting to know the same thing. I did some testing tonight. To start with, I think you should use closer to 150 main (bottom), and 150 air corrector (top). It depends on what size carbs they are, and the main venturi size.
I am using a 1812cc 2T-G, with 305 degree cams. I have 40m Solex carbs, 32mm venturi. 160 main jets, 140 air jets, 57.5 slow jets. Mostly, it runs realy well, good power. But I am still getting a small carb pop at 7000rpm which mucks up power alot and it will not like going to 8000rpm. I am thinking I need to go even small in the air corrector, like 130 or something. Anyone have more idears?
A mates standard 18R-G runs well with the standard jets. 125 mains, 140 airs I think.
joecoolmk2
Re: what size jets Wed, 18 August 2004 00:09 Go to previous messageGo to next message
i don't know much about how sidedrafts work. i've got triple 40mm solex c.40 ADDHE sideys i'm gonna put on a 4M. the crbies came off an alfa romeo of the same size(2.6). i'm gonna get the cam reprofiled, dunno whats best for it. minor port and polish. any suggestions?
Mr DOHC
Re: what size jets Wed, 18 August 2004 11:10 Go to previous message
i was told that i should have about 160 up top and down below, or maybe even go to a 170 or 180 down below, but no more than a 160 {i currently have 200 Confused },
and u may know that u cant get solex jets anymore, but what u can do is, tap the air bleed jet holder in the emulsion tube to 5 x 0.8mm abd weber 32/36 just will fit, and they cost like $4 each Smile
Previous Topic:[AE86] aircon - easy to install?
Next Topic:Cam Specs
Current Time: Fri Nov 20 23:12:00 UTC 2026
Total time taken to generate the page: 0.0083370208740234 seconds
