Toymods » Tech & Conversions » 1UZ aircon and alternator
SupraPete
1UZ aircon and alternator Wed, 18 September 2002 00:55 Go to next message
The engine I've found doesn't have aircon or alternator, can I put the ones off my 7MGTE onto it?
They said (japimports) that its better to use my current ones as they'll work with my current lines. is this true?
Re: 1UZ aircon and alternator Wed, 18 September 2002 01:02 Go to previous messageGo to next message
I'd be surprised if your 7M stuff fits without a lot of stuffing around. The 1JZ uses a single serpentine belt to run everything, as opposed to the 7M which has several regular v belts. As usual, the toothless inbred wrecker dudes are full of crap.
Re: 1UZ aircon and alternator Wed, 18 September 2002 01:27 Go to previous messageGo to next message
1UZ Norbie
biased99
Re: 1UZ aircon and alternator Wed, 18 September 2002 01:56 Go to previous messageGo to next message
Hey Pete,
Short answer is no.
You will need to get both ancillaries for the 1UZ. Also, you will need to make sure that you get ancillaries for the particluar car/engine combo. Eg. there are two different Soarer "incarnations" of the 1UZ...one has two ancillary belts, the other one, and they AREN'T interchangeable. I'd suggest the Crowns are different again.
My suggestion would be to look for something that is complete with ancillaries...
SupraPete
Re: 1UZ aircon and alternator Wed, 18 September 2002 02:07 Go to previous messageGo to next message
What won't fit? the belts? the mounts? These can't be changed?
Re: 1UZ aircon and alternator Wed, 18 September 2002 02:27 Go to previous message
justcallmefrank wrote on Wed, 18 September 2002 11:27
1UZ Norbie
Ooops. Oh well it's pretty much the same deal - being a totally different type of enigine, you wouldn't expect the accessories to bolt up without a lot of custom fabrication work. It's much easier to get the original accessories and have the hoses/lines/wires modified to your car.
Previous Topic:Ideas to Install a CD-Stacker in SA-63?
Next Topic:Anyone got a wiring diagram for 4A-GZE loom and ecu?
Current Time: Mon Jun 15 21:25:49 UTC 2026
Total time taken to generate the page: 0.0040180683135986 seconds
