Toymods » Tech & Conversions » DIY wheel alignment
b1gb3n
south Melbourne/KL
DIY wheel alignment Tue, 17 August 2004 17:18 Go to next message
anybody know any link that explains how to do wheel alignments at home?
b1gb3n
south Melbourne/KL
Re: DIY wheel alignment Tue, 17 August 2004 18:16 Go to previous messageGo to next message
which nut is it to adjust the toe in & out?
Re: DIY wheel alignment Tue, 17 August 2004 22:38 Go to previous messageGo to next message
Yeah I do it all the time with blocks, sticks and a measuring tape. Rough, but does the job.
Celica_John
Re: DIY wheel alignment Tue, 17 August 2004 22:44 Go to previous messageGo to next message
$40 seems to be the going rate for a wheel alignment. not exactly a king's ransom.
DTrain
Re: DIY wheel alignment Tue, 17 August 2004 23:55 Go to previous messageGo to next message
dont be a tightarse, pay the $50 bucks, at least you'll know its done right
gold28
Madrid - Spain
Re: DIY wheel alignment Wed, 18 August 2004 00:17 Go to previous messageGo to next message
You can get a rough toe alignment by measuring the distance between the forward and aft parts of the wheel rims and adjusting the tie rod ends accordingly. If you have recently changed a steering or front suspension component, I strongly advise checking this prior to driving anywhere. I must stress though that depending on the equipment you have used to measure it, it will likely be very rough and should only be used to get you to an alignment shop for a proper job. Having said that you should be able to get it to within a tollerance of about 1 degree, so it should be drivable given some tire wear. I would advise going slightly toe in if your not sure as toe out makes for interesting driving qualities.
Re: DIY wheel alignment Wed, 18 August 2004 00:41 Go to previous messageGo to next message
Hey Anthony, do you still have the template for your camber guage that you made? I am thinking of making one up Smile
EVOSTi
cambo
      no
Re: DIY wheel alignment Wed, 18 August 2004 11:16 Go to previous messageGo to next message
i used to pay $40 for a wheel allignment and an extra $50! for the camber cause of the adjustable rose jointed control arms. then i went to bridgestone and they only charged me $35 all up. pretty good i reckon.
b1gb3n
south Melbourne/KL
Re: DIY wheel alignment Wed, 18 August 2004 12:42 Go to previous messageGo to next message
ill go look for bridgestone on yellow pages then...
Any idea how much camber nuts cost?
EVOSTi
cambo
      no
Re: DIY wheel alignment Thu, 19 August 2004 05:36 Go to previous messageGo to next message
camber nuts? do you mean the off-centre nuts used on some FWD struts to adjust camber? or are you talking aftermarket, like those adjustable strut tops?
b1gb3n
south Melbourne/KL
Re: DIY wheel alignment Fri, 20 August 2004 05:18 Go to previous messageGo to next message
should be the offcenter nuts. Located above disc brakes. Nut holds the absorbers to the disc (around there) as well.
EVOSTi
cambo
      no
Re: DIY wheel alignment Sat, 21 August 2004 00:19 Go to previous message
if your car doesnt already have them you cant simply put them on.
Previous Topic:18r-gu head no. 88251 - good ? bad?
Next Topic:Spring on Timing Belt Tensioner (4A)
Current Time: Thu Nov 19 09:36:41 UTC 2026
Total time taken to generate the page: 0.0071041584014893 seconds
