Toymods » Tech & Conversions » power steering cooler..high pressure?
V8_MA61
power steering cooler..high pressure? Wed, 18 August 2004 01:45 Go to next message
I got a tranny cooler off a magna..steel tanked bar + plate style.
Im intending on using it for my power steering cooler, as i hear the toyota racks have a habit of failing under heat.
Now, is the line for the cooler high-pressure? I.e will it blow my cooler apart? or will it be fine?
Blake
Re: power steering cooler..high pressure? Wed, 18 August 2004 01:48 Go to previous messageGo to next message
Run it on the low pressure side.
V8_MA61
Re: power steering cooler..high pressure? Wed, 18 August 2004 03:38 Go to previous messageGo to next message
ie the one from the reservoir?
it formerly came:
from the reservoir, through the rod, and down into the rack..all of the hoses look as if they are high pressure Confused
Re: power steering cooler..high pressure? Wed, 18 August 2004 03:52 Go to previous messageGo to next message
The hose that goes from the rack back to the bottle is the low pressure one - there should already be a loop of pipe in it somewhere
V8_MA61
Re: power steering cooler..high pressure? Wed, 18 August 2004 04:02 Go to previous messageGo to next message
there isnt one that goes from the rack to the bottle Confused
it goes from the pump, to the bottle, to the cooler, and back down to the rack...and then back to the pump i believe..
Bugman
Re: power steering cooler..high pressure? Wed, 18 August 2004 04:45 Go to previous messageGo to next message
it's the other way round
the bottle (resevoir)feeds the pump from the bottom
pump pumps into the rack(high pressure) then comes out of the rack, goes thru cooler and into the top of the resevoir
Bugman
the only barbed fittings that are neccassary are for the pump to the rack everything else can be hose clamp etc as its only neccassary to seal them so the liquid doesnt come out not under high pressure.
V8_MA61
Re: power steering cooler..high pressure? Wed, 18 August 2004 04:48 Go to previous messageGo to next message
so can i use the existing setup (way the pipes were) with the cooler or??
Re: power steering cooler..high pressure? Wed, 18 August 2004 07:06 Go to previous messageGo to next message
Why are you making this so diffcult?? Remove factory "cooler" (ie bit of pipe), replace it with real cooler. Done.
SupraPete
Re: power steering cooler..high pressure? Wed, 18 August 2004 07:31 Go to previous messageGo to next message
Norbie is right, it shouldn't be that difficult.
There are 2 lines that go towards the front of the car (sitting above the chassy rail directly opposite the battery). Put your cooler on these. They'll need a clamp, but not a high pressure fitting.
http://www.vss.com.au/supra/supra3.jpg
these 2 here ^ ^
On this pic there are two PS lines that are clamped that point towards the front of the engine. These are the ones you want to put the cooler on.
SupraPete
Re: power steering cooler..high pressure? Wed, 18 August 2004 07:34 Go to previous messageGo to next message
I keep forgetting your talking about a MA61 as your pic has a MA70.
I don't know where the lines are in a MA61 so my post above might just be total crap. (but relevant if you're talking about a MA70)
Re: power steering cooler..high pressure? Wed, 18 August 2004 07:42 Go to previous messageGo to next message
Find power steering pump.
You will see 2 hoses coming from it. One comes out of the bottom of it and heads off to the rack. This is your high pressure line. It will be rather securely attached to the pump with a big flare nut or a big banjo fitting (can't remember which).
You will see the other line goes to the reservoir. Trace this line back and you will see that it heads to some pathetic loop of pipe at the front of the car that Toyota dared to call a power steering fluid cooler. This is the low pressure side of your power steering circuit.
Replace this loop of pipe with your Magna cooler.
Job done. Enjoy alcoholic beverage of your choice..
BlackSupra
Re: power steering cooler..high pressure? Wed, 18 August 2004 07:46 Go to previous messageGo to next message
Id take a picture but its pissing down.
Look inside your front bar, there is a crappy sideways 'U' pipe which is the factory cooler. As describd above its already on the low pressure line, remove it and replace with your cooler.
Too easy.
people100
Rocklea qld
Re: power steering cooler..high pressure? Wed, 18 August 2004 10:08 Go to previous messageGo to next message
it wont matter were it does...the cooler will handle around 120 psi anyway unless there is a problem with it and if there is then u dont want that in your car anyway. if you are worried let me know and ill test for ya.
V8_MA61
Re: power steering cooler..high pressure? Wed, 18 August 2004 13:00 Go to previous messageGo to next message
I know what the bloody cooler looks like and what lines originally went to it. Im simply querieng whether or not those oringal lines are high pressure and will damage the cooler.
read my first post.
edit: i now know those lines are the low pressure side of the pump, thanks dave. Thats all i need to know.
[Updated on: Wed, 18 August 2004 13:07]
V8_MA61
Re: power steering cooler..high pressure? Wed, 18 August 2004 13:12 Go to previous messageGo to next message
oh and pete, its the same setup as an ma70..which ill also be replacing soon..i got 3 magna coolers Wink
Re: power steering cooler..high pressure? Wed, 18 August 2004 13:16 Go to previous messageGo to next message
slightly OT: does the MA61 power steer system have problems with heat?
apart from mechanical failures of seals (which will happen with regular use so they're not an issue) - is the stock system prone to overheating or becoming troublesome when the fluid gets hot?
the reason i ask is the hydraulics you find on a cement truck have a reasonable small cooler considering the work they do, especially the direct drive motors turning the barrel- and my G/F father's tractor has massive hydraulics for 3PL, big front blade, steering, etc and it has no cooler, just a big reservoir, and it's been run hard all day long without any issues.
So maybe the pissy cooling pipe is all that's needed? (if the fluid and pump are up to scratch)
V8_MA61
Re: power steering cooler..high pressure? Wed, 18 August 2004 13:19 Go to previous messageGo to next message
my rod used to get pretty hot when driving, ill feel the ma70s tommorow after a bit of a drive. but yeah they do run hot...and the reservoir is only tiny really...
Re: power steering cooler..high pressure? Wed, 18 August 2004 14:59 Go to previous messageGo to next message
Does anyone feel brave enough to mention 'PS fluid temp' and 'Commodore' in the same sentence? Evil or Very Mad
bbaacchhyy
Re: power steering cooler..high pressure? Wed, 18 August 2004 15:20 Go to previous messageGo to next message
mrshin wrote on Thu, 19 August 2004 00:59
Yep, it is a known problem, especially when a long fang has been had. I know with the new car (VZ), they have chnaged the coolers to the rod type with the spring wound arount to get better cooling and have sourced new pumps (and the reservoir is a little different as well.
For my MA61, I'll be replacing the "ideways plain U" (well described by BlackSupra Cool ) with a Monaro version until I get tired of it and remove the PS as dione by Ed_MA61
Oorooo
Re: power steering cooler..high pressure? Wed, 18 August 2004 22:35 Go to previous messageGo to next message
I killed two PS racks (ie end seals) in the space of 3 months. I don't know exactly why this happened, but I was regularly participating in sprints at Queensland Raceway at the time, so my theory is the extra stress that placed on the PS system made it get uber-hot, and that buggered the seals (or at least helped).
In any case, installing a good PS cooler is cheap and easy so I'm going to do it. It will be interesting to see if my currently-functioning rack survives the next round of QR sprints once I've got the car running again. Smile
V8_MA61
Re: power steering cooler..high pressure? Thu, 19 August 2004 06:02 Go to previous messageGo to next message
thanks fellas.
one last question though, the hose that used to go to the rod, was like hi pressure hose...do i need to buy this again, or will normal a/t fluid hose be sufficient?
Re: power steering cooler..high pressure? Thu, 19 August 2004 06:07 Go to previous messageGo to next message
As has already been explained several times, that's the low pressure side of the system, ie there's practically no pressure in there at all. Use any hose you like.
rob_RA40
c'town, NSW
Re: power steering cooler..high pressure? Thu, 19 August 2004 06:09 Go to previous messageGo to next message
is this thread still going? Eye Spin Eye Spin Eye Spin
V8_MA61
ta Smile
indian
south east - melbourne
Re: power steering cooler..high pressure? Thu, 19 August 2004 07:15 Go to previous messageGo to next message
SO the little spring like devicee -- running from the power steering reservoir ,in my gz20 soarer is the shitty cooler u guts talking about ,
so is it better off replacing it or just leave it , as i thought it was ok in doing the job
apparently not , lollllll
i was gonna do the tranny cooler , do u guys think is hould replace the power steering one as well
V8_MA61
what magna cooler was it what year , and how much , i got charged 22 for a nippon denso from a ford
V8_MA61
Re: power steering cooler..high pressure? Thu, 19 August 2004 11:36 Go to previous messageGo to next message
off tp,tr,ts magna auto trans coolers. They are pretty big, probly too big for a ps cooler! Laughing
I got 3 for free...i work at a wreckers Wink
indian
Re: power steering cooler..high pressure? Thu, 19 August 2004 22:37 Go to previous message
cool
god damn wreckers only have fordsand holdens here
Previous Topic:18rg head removing/installing advice
Next Topic:3TGTE turbo manifold
Current Time: Sat Nov 21 21:47:49 UTC 2026
Total time taken to generate the page: 0.0067019462585449 seconds
