Toymods » Tech & Conversions » 18rg head removing/installing advice
RA40Celica
Hobart
  chris_rg@jabber.org
18rg head removing/installing advice Thu, 19 August 2004 10:57 Go to next message
hi,
my 18rg head is coming off tomorrow. I have information from manuals such as head bolt tension, tightening pattern, cam timing, etc.
Is there any other advice people can give from experience?
do i need to recheck the head bolt tension after running for a bit?
in the book it says to put sealant on three points, i can see two points are probably for the timing chain cover joint... what's the other one? it goes over a hole.
Chris
earlyrolla
Re: 18rg head removing/installing advice Thu, 19 August 2004 23:39 Go to previous message
Use Hylomar on the new head gasket.
Re-tension after 500-1000kms by marking the top of each bolt with some white out, undoing each bolt and re-tensioning in sequence (only undo one bolt and re-tension it at a time). The white out is to see if the bolt screws up any tighter. On mine I got about 1/4 more turn on re-tensioning the each bolt.
Smile
Previous Topic:GZE throttle body
Next Topic:power steering cooler..high pressure?
Current Time: Tue Oct 20 06:33:44 UTC 2026
Total time taken to generate the page: 0.0049479007720947 seconds
