Toymods » Tech & Conversions » Interesting idea, maybe
Simple
icon3.gif  Interesting idea, maybe Thu, 19 August 2004 12:21 Go to next message
Ok,I want to know if it would be possible or at all usefull to somehow put a fan in the air inlet pipe? dont laugh yet, ive done a few calcs:
i have a 01' rolla, so its 1.8L which = 0.0018m sq.
so at 2000rpm it is sucking around 3.6m sq/min
and at 5000rpm its sucking around 9m sq/min
And a 120mm computer case fan can blow up to around 2.5m sq/min
so if i were to take 4 X fan it would blow - 10m sq/min
which is more than the engine requires (up to 5555.55rpm)
therefore for the engine to suck its required air volume at any given rpm it would be doing less 'work' therefore = more power!
there is also the issue of wiring the fans to a car battery, but i figure that's a minor detail.
now you can laugh...
Please let me know if you dont agree with the calculations
(or the idea at all)
sorry to get all 'maths' on you
thanks.
matt_84
Ipswich
Re: Interesting idea, maybe Thu, 19 August 2004 12:35 Go to previous messageGo to next message
This should be informative.
http://www.autospeed.com/cms/article.html?&A=0 237
Simple
Re: Interesting idea, maybe Thu, 19 August 2004 13:41 Go to previous messageGo to next message
Thanks for the link, but the calculations on the page are a bit funny, i can get a 120mm fan to do 80cfm (2.3m sq./min)
(jaycar cat. YX-2516)
They use as their comparison the figue of ony 18cfm. they are also using a 3L v6 engine, where as mine is only 1.8L 4 pot.
i recalculated, and before i didn't take into concideration the fact the the intake stroke is only on 2 or 4 strokes, so that means i would get the same effect with only 2 fans & not 4.
does anybody know how to wire a 12v 380mA fan to a car battery?
matt_84
Ipswich
Re: Interesting idea, maybe Thu, 19 August 2004 13:50 Go to previous messageGo to next message
I know its cynical, but I figure that the amount of money car companies put into engineering and research, would have determined if a few relatively cheap fans can increase volumetric efficiency.
But thats ust my 2 cents.
Re: Interesting idea, maybe Thu, 19 August 2004 22:36 Go to previous messageGo to next message
A pissy little computer fan might be able to push 2.5m sq/min into free air, but put the smallest restriction in front of it and watch that figure drop through the floor.
What it comes down to is this: it takes large amounts of power (we're talking kilowatts here) to get any noticeable increase in manifold pressure at high rpm, and no computer case fan can deliver that sort of power.
Believe me, you're not the first person to come up with this brilliant idea (I remember people discussing it on the aus.cars newsgroup in the mid 90's) but strangely enough you don't see a lot of cars getting around with computer case fans taped to the airbox? Laughing
Re: Interesting idea, maybe Thu, 19 August 2004 23:37 Go to previous messageGo to next message
well, in the movie "metalskin" he put a vacuum cleaner on the intake Wink
i actually did do this.. got an old electrolux and attached it to the intake of my datto Stanza SSS... just for kicks (in blowing mode of course)
made it idle a little higher, but throttle response off idle was much faster.. i think the vac ran out of puff when holding throttle at a steady 2000rpm tho...
so anything more than a 2000rpm idle was already going past it's capability... and i think a 1200W vac will do more than a 6w fan.
what you want is a SUPERCHARGER Very Happy
Re: Interesting idea, maybe Thu, 19 August 2004 23:45 Go to previous messageGo to next message
Haha my mate put a vac on his 2tg ta22. Mounted it and everything, had a belt running it.. Was ok until 2000rpm or so when the bearings or bushes whatever is in a vac fell to pieces.
Simple
Re: Interesting idea, maybe Fri, 20 August 2004 02:45 Go to previous messageGo to next message
thats a good point norbie, about the fan not having enough power to increase manifold pressure, which is true of course. that though is not the idea. the idea is to simply reduce the amount of work the engine needs to do to suck its required air, and not increase the pressure of the air going in.
rob_RA40
c'town, NSW
Re: Interesting idea, maybe Fri, 20 August 2004 03:58 Go to previous messageGo to next message
what about the work the engine has to do to spin the loaded alternator because of the computer fan?
there is no free energy here, only free energy to play with is moving exhaust gas and engine heat.
edit: speeling
[Updated on: Fri, 20 August 2004 03:59]
CLG
Perth, Western Australia
Re: Interesting idea, maybe Fri, 20 August 2004 04:01 Go to previous messageGo to next message
oldcorollas wrote on Fri, 20 August 2004 07:37
ROFLMAO, what memory, thanks for draggin it up Stew!!! The scary realisation is you tried it??? Bored that day hey?
b1gb3n
south Melbourne/KL
Re: Interesting idea, maybe Fri, 20 August 2004 05:32 Go to previous messageGo to next message
well, my basic opinion is that a fan to do that would require lots of energy to provide enough air. If that much energy is required for the fan, the engine would probably already lose some power somewhere. So basically u would be back to square one or end up losing more power in the fan.
Just my thoughts. No scientific proof or calculations to support my theory.
Re: Interesting idea, maybe Fri, 20 August 2004 05:45 Go to previous messageGo to next message
CLG wrote on Fri, 20 August 2004 14:01
Laughing yeah just a little.... 1st car.. vacuuming it... hmmmm "i wonder what would happen if..."
i was surprised it made any difference, and dissapointed it made little difference.
btw, i did it long before i watched metalskin... man thats one fucked up movie... good aussie flick tho Very Happy
Re: Interesting idea, maybe Fri, 20 August 2004 06:12 Go to previous messageGo to next message
b1gb3n wrote on Fri, 20 August 2004 15:32
Except for the Law of Conservation of Energy. Smile
Cyber-punk
Brisbane, QLD
Re: Interesting idea, maybe Fri, 20 August 2004 08:41 Go to previous messageGo to next message
Norbie wrote on Fri, 20 August 2004 16:12
Laws are made to be broken... Rolling Eyes
Re: Interesting idea, maybe Fri, 20 August 2004 09:55 Go to previous messageGo to next message
as mentioned, a supercharger will push the kind of air you're after
electronically power forced induction, from all the reading I've done, blows goats.
takai
Re: Interesting idea, maybe Fri, 20 August 2004 10:06 Go to previous messageGo to next message
Unless its like a 3phase blower which you trail around on a lead.
Would be good, till you got about 25m from home.
Re: Interesting idea, maybe Fri, 20 August 2004 10:59 Go to previous messageGo to next message
Here's an even easier way to prove it to yourself; fire up your car, and stick your hand over the throttle while free revving to, say, 5000rpm. Do the same to a computer fan air intake. Notice a difference? Also, remember that your car engine is only able to generate a couple of KW while free revving like this...
Re: Interesting idea, maybe Fri, 20 August 2004 14:47 Go to previous messageGo to next message
mrshin wrote on Fri, 20 August 2004 20:59
NOTE: not recommended if you want to keep your hand. Shocked
Lachie
Re: Interesting idea, maybe Sun, 22 August 2004 00:58 Go to previous message
takai wrote on Fri, 20 August 2004 19:36
I like the idea of the 3phase blower.
What if you got a 400m long (have to be longer but anyway)exstenion cord and just used it down the quarter?
That would turn a few heads at the drags Laughing Laughing Laughing Laughing
Previous Topic:Blitz Supercharger (JZA80)
Next Topic:Machining Wheels
Current Time: Mon Oct 26 15:46:44 UTC 2026
Total time taken to generate the page: 0.053421020507812 seconds
