Toymods » Tech & Conversions » 100kw engine problem, maybe oil related
carsanactra
melbourne
100kw engine problem, maybe oil related Thu, 19 August 2004 13:54 Go to next message
the problems are comming from my 100kw conversion into an ae82.
when i first start the car, if i try to move it in the first couple of minutes of starting it, i get troubles. then engine wont rev like it does usually, untill a couple of minutres after starting it.
if i try slipping the cluth out to reverse out of the garage at anything under 2000rpm the engine just dies. i really have to rev it to about 3k rpm and then let the clutch out just to reverse! after letting the car warm up a little, this problem goes away, and i can take off normally.
i think its some problem with my oil. when i start to rev the engine, the oil light slowly fades on, and then fades away by 2500rpm. also if i slightly put my foot on the accelrator, just enough for the revs to very slowly build up, when the revs hit 2000rpm, it hesitates and dropes down a bout 400-300revs, slowly builds up to 2000rpm and then drops a couple hundred revs again, over and over!
anythingover 3000rpm is fine, the oil light doesnt come on and the car revs out hard all the way to 7000rpm. although since this problem ive recently had with driving the car without letting it run for a bit, it the whole rev range feels a bit sluggish?
whats the diagnosis? i think it could be my oil pump, or maybe i just need an oil change?
Re: 100kw engine problem, maybe oil related Thu, 19 August 2004 14:20 Go to previous message
sounds like you have two problems:
-attend to the low oil pressure issue first
-the other issue reads like a air leak in the intake somewhere.
when did you last change the oil? is it at the full level on the dipstick? fwiw, oil light should be out at idle speeds, even when warm.
the hunting for revs on slight throttle opening sounds like air leak. Check you pipes/clamps/hoses from air filter thru to head.
Previous Topic:LDS For T292
Next Topic:Highflowing my CT26
Current Time: Thu Oct 15 17:45:42 UTC 2026
Total time taken to generate the page: 0.38456606864929 seconds
