Toymods » Tech & Conversions » Fitting a higher flow fuel pump to a 7M-GTE
bbaacchhyy
Fitting a higher flow fuel pump to a 7M-GTE Thu, 19 August 2004 21:38 Go to next message
Just s quick question in that I need to confirm what I am thinking.
I have a Bosch hi flow pump (I think it is a 910 unit ) that is to go into a 7M-GTE powered Mk2. The pump will be changed now to cater for future mods such as decent I/C, higher boost etc.
As this pump has a higher flow capacity, if nothing is changed over the stock pump, will i have to reduce the fuel pressure so that I maintain the current fuel delivry for the tune and then modify it alter as I complete the other mods ?
Will I need to increase the size of the fuel return line to prevent higher fuel pressure as there isn't sufficient fuel flow back to the tank due to restriction ?
Any help is greatly appreciated
Michael B
Re: Fitting a higher flow fuel pump to a 7M-GTE Thu, 19 August 2004 22:49 Go to previous messageGo to next message
1. No you should never have to change your fuel pressure unless you're being bodgy (ie trying to push stock injectors further than they should go).
2. Factory return lines are a pretty good size, so it's unlikely they'll present a restriction unless you have a ludicrously large fuel pump. I don't have any problems with my 255lph Walbro, but if you're worried it's easy enough to hook up a pressure gauge and watch what happens.
bbaacchhyy
Re: Fitting a higher flow fuel pump to a 7M-GTE Tue, 24 August 2004 05:25 Go to previous message
Cheers Norbs.
Previous Topic:how to tell which LSD by jacking the car up ?
Next Topic:anyone got/know about Tial BOV's?
Current Time: Sun Nov 1 11:53:00 UTC 2026
Total time taken to generate the page: 0.0049519538879395 seconds
