Toymods » Tech & Conversions » 12R, turbo or upgrades?
12R4banger
icon10.gif  12R, turbo or upgrades? Fri, 20 August 2004 03:13 Go to next message
hey all I need some ideas for getting more power out of the tough little 1600 toyota 12R engine
I have one in my corona and I wouldn't mind a few more killawatts to play with cheers.
SeptemberSquallIndustries
Re: 12R, turbo or upgrades? Fri, 20 August 2004 03:20 Go to previous messageGo to next message
18R-G.
12R4banger
Re: 12R, turbo or upgrades? Fri, 20 August 2004 03:24 Go to previous messageGo to next message
G being the japanese 18r ? how much power and how bothersome to install?
the 12r is a 67kW 1600
Re: 12R, turbo or upgrades? Fri, 20 August 2004 03:34 Go to previous messageGo to next message
18R-G is:
DOHC w/ bucket and shim valve train
Dual Solex sidedraft carburettors
1968CC
~140HP in original form
It's available in Australia second hand from time to time.
Shouldn't be hard to adapt to your car. Perhaps the R motor's engine mounts/sump may interchange to give you a workable combination. What transmission are you currently running?
As a point of interest, is your 12R a 5 main bearing or 3 main bearing engine?
12R4banger
Re: 12R, turbo or upgrades? Fri, 20 August 2004 04:00 Go to previous messageGo to next message
she is a 3 main bearing engine strapped to a bullet proof 4 speed manuel
the gearbox case is made of Iron if that helps identify the box?
Re: 12R, turbo or upgrades? Fri, 20 August 2004 04:26 Go to previous messageGo to next message
If you have an RT81, the box is a W40 (4 speed variant of the Celica steel case 5 speed).
I really wouldn't bother working the little 12R. I know someone who slotted a Rover V8 in one.
Re: 12R, turbo or upgrades? Fri, 20 August 2004 04:33 Go to previous messageGo to next message
The W40 should bolt to the 18R-G.. I think.
It's bolt-in for W50 transmissions, but I seem to remember old W40's having some strange non-standard or non-interchangable characteristics compared with W5# boxes..?
That may have been for extension housings though..?
12R4banger
Re: 12R, turbo or upgrades? Fri, 20 August 2004 04:39 Go to previous messageGo to next message
Yes correct she is an RT81
does anyone know wether (just for kicks ) the 12R is built stronge enought to take a turbo even if it is a small one
remembering this is a cast iron head truck engine
PS I have 2 spare 12Rs in full running order
and a 13t-u that I'm not sure if it will even kick over.
Re: 12R, turbo or upgrades? Fri, 20 August 2004 04:51 Go to previous messageGo to next message
The bellhousing for the 12R to W40 will be different to the 18R to W40 bellhousing. The 3 main bearing R motors have a different tail on the motor - almost like a cowl around the flywheel that is an extension of the block.
As a side note, the W55-9 bellhousings will not bolt up to the W40 or W50 boxes.
Re: 12R, turbo or upgrades? Fri, 20 August 2004 04:58 Go to previous messageGo to next message
Okay, so a new motor will require a transmission change.
12R4banger
Re: 12R, turbo or upgrades? Fri, 20 August 2004 05:43 Go to previous messageGo to next message
I don't realy whant to bother with changing all of the drive train so just stick to suping up the engine for now
12R4banger
Re: 12R, turbo or upgrades? Fri, 20 August 2004 06:51 Go to previous messageGo to next message
Hmmm gotta keep replyin to keep the thread at the top
what ever happened to shaving the head ????? it was all the rage when my car was made
would shaving the head enough to bring original compression back cause so much blow back into the crank that it wouldn't be woth doing???
and keep the idea's commiong about turboing the old girl.
Re: 12R, turbo or upgrades? Fri, 20 August 2004 07:30 Go to previous messageGo to next message
Nah. To run the 18RG all he needs is a bellhousing from a 4 speed RT104. Probably a whole $30 from your friendly wrecker.
Obviously you'll need to check where the engine mounts are - the 12R (and I think all those 3 main bearing motors) has engine mounts right at the front. Not sure where the 18RG mounts are located.
[Updated on: Fri, 20 August 2004 07:40]
Bradelz
Tamworth
Re: 12R, turbo or upgrades? Fri, 20 August 2004 11:45 Go to previous messageGo to next message
hey man,
get a 4M should fit nicely and go like the clappers.
brad
12R4banger
Re: 12R, turbo or upgrades? Fri, 20 August 2004 12:43 Go to previous messageGo to next message
OK I'm well aware that dropping a racing engine or a just plain bigger donk would make my corona faster what I'm more interested in is the novelty of getting more power out of the 12R I need every ones thoughts on things like either putting a head spacer in and adding a turbo and an SU carby orrrrr shaving the head and extracting her
ya know things like that
12R4banger
Re: 12R, turbo or upgrades? Fri, 20 August 2004 12:45 Go to previous messageGo to next message
come to think of it hey Brad and others who know about the 7R
I wonder if it would be worth it buying Joshes 7R and boring it out and extracting it
how much power would that end up ??????
Re: 12R, turbo or upgrades? Fri, 20 August 2004 13:42 Go to previous messageGo to next message
toyotacrown76 wrote on Fri, 20 August 2004 21:45
hey man,
brad
You've got to be joking. Seen an RT81? Pass the gas axe...
Re: 12R, turbo or upgrades? Fri, 20 August 2004 14:41 Go to previous messageGo to next message
12R4banger wrote on Fri, 20 August 2004 22:45
Let me gaze into my crystal ball.
Wait a minute! I'm getting something...
"Fuck all."
Hope that helps. Smile
Re: 12R, turbo or upgrades? Fri, 20 August 2004 21:27 Go to previous messageGo to next message
I believe I gave you my opinion a little earlier.
gianttomato wrote on Fri, 20 August 2004 14:26
Bradelz
Tamworth
Re: 12R, turbo or upgrades? Fri, 20 August 2004 22:41 Go to previous messageGo to next message
oi adrian, josh is still selling it. also why dont you get the 13T-U and stick that in the corona?
those coronas look awesome whats your problem are you blind?
brad
12R4banger
Re: 12R, turbo or upgrades? Fri, 20 August 2004 22:58 Go to previous messageGo to next message
well ok lets talk about the 13T-U this is a very torquey 1.8 OHC 4cyl wich is rumoured to be one of the free'st revving engines for it's time (it's suposed to have a twin chamber head) inventing a 13T-UGTE sounds kinda cool
by the way I LOVE Torque!! nothing makes me smile like low revs wet weather wheelspin in 3rd gear around corners and roundabouts
12R4banger
Re: 12R, turbo or upgrades? Fri, 20 August 2004 23:31 Go to previous messageGo to next message
bump
Re: 12R, turbo or upgrades? Sat, 21 August 2004 00:06 Go to previous messageGo to next message
toyotacrown76 wrote on Sat, 21 August 2004 08:41
He was responding to your suggestion of a 4M in an RT81. If anyone's blind it must be you if you think that great lump is going to fit. Rolling Eyes
Re: 12R, turbo or upgrades? Sat, 21 August 2004 00:07 Go to previous messageGo to next message
12R4banger wrote on Sat, 21 August 2004 08:58
...inventing a 13T-UGTE...
Ever heard of a 3TGTE? Better idea, less hassle.
12R4banger
Re: 12R, turbo or upgrades? Sat, 21 August 2004 01:10 Go to previous messageGo to next message
ok so no one on here has any clue about tuning you all just pay thousands and put huge donks in your cars.....????
my car weights 950kgs I just whant some tips for cheap ways to get my cars power near or over it's original power level
munki
Gold Coast
Re: 12R, turbo or upgrades? Sat, 21 August 2004 01:40 Go to previous messageGo to next message
12R4banger wrote on Sat, 21 August 2004 11:10
Rolling Eyes
Re: 12R, turbo or upgrades? Sat, 21 August 2004 01:50 Go to previous messageGo to next message
No. None of us have any idea.
Turbocharge your 12R. Inform us of the total cost and nett power improvement. We eagerly await your no doubt outstanding results.
12R4banger
Re: 12R, turbo or upgrades? Sat, 21 August 2004 01:57 Go to previous messageGo to next message
yeah ok I'm not writing anything else in this thread
munki
Gold Coast
Re: 12R, turbo or upgrades? Sat, 21 August 2004 02:05 Go to previous message
have a hissy fit then.
but the cheapest easiest and best power gains are to be had from conversions not fixing up your current motor
Previous Topic:New springs and kyb shocks $928 fitted expensive?
Next Topic:RWD Bigport inlet manifold issues
Current Time: Sun Nov 1 11:15:28 UTC 2026
Total time taken to generate the page: 0.1013331413269 seconds
