Classifieds » Miscellaneous » JZA 70 front cut stuff
JAZE
cronulla
JZA 70 front cut stuff Wed, 18 September 2002 07:58 Go to next message
dash + loom
ABS gear
brake calipers
1 JZ bare motor (good cond)
JZ air con compressor
power sreer pump
altenator
wiring loom (no computer)
power steering rack
and some other stuff
any takers??
ed_ma61
Lost in the K hole
Re: JZA 70 front cut stuff Wed, 18 September 2002 09:25 Go to previous messageGo to next message
how much for the calipers?
ed
JAZE
cronulla
Re: JZA 70 front cut stuff Wed, 18 September 2002 10:53 Go to previous messageGo to next message
id say $60 would get you both
ed_ma61
Lost in the K hole
Re: JZA 70 front cut stuff Wed, 18 September 2002 10:57 Go to previous messageGo to next message
sold!!!!!!
JAZE
cronulla
Re: JZA 70 front cut stuff Wed, 18 September 2002 11:04 Go to previous messageGo to next message
cool.
Manny
Re: JZA 70 front cut stuff Wed, 18 September 2002 11:46 Go to previous messageGo to next message
wiring loom - how much?
JAZE
cronulla
Re: JZA 70 front cut stuff Wed, 18 September 2002 12:45 Go to previous messageGo to next message
$60 should be fine also Smile
Manny
Re: JZA 70 front cut stuff Wed, 18 September 2002 13:03 Go to previous messageGo to next message
sold - you got mail
Drifta
Re: JZA 70 front cut stuff Wed, 18 September 2002 13:44 Go to previous messageGo to next message
Do u have an intercooler?
mrsoopra
Re: JZA 70 front cut stuff Wed, 18 September 2002 13:48 Go to previous messageGo to next message
How bare is the engine?? And how much for it? Does it have flywheel etc etc??
MrSoopra
MA61 Supra (1JZGTE'd)
TOY77
Re: JZA 70 front cut stuff Wed, 18 September 2002 21:17 Go to previous messageGo to next message
G'day,
how bout the brake master cylinder...
not the booster, just the bit that attatches to the front with the four bolts?
$50?
Stew
TA22-3SGTE
MACKAY
Re: JZA 70 front cut stuff Thu, 19 September 2002 01:36 Go to previous messageGo to next message
If it is a manual how much for the complete pedal assembly and clutch master cylinder. Does it have a gearbox.
Thanks Robbie
JAZE
cronulla
Re: JZA 70 front cut stuff Thu, 19 September 2002 13:42 Go to previous messageGo to next message
here goes ,
the engine is sump, head,block rocker covers cams ect also water pump assembly, $250 is what im after for it , theres no carbon deposits its all nice and clean and honey ytellow up in the block (had the sump off) tag says its done 92,000 i also have another engine with all the gear on it which is stuffed (turbos are good though), its not a manual,manual 1 jz are as rare as chicken teeth i got my stuff of a 2JZGE but i have a friend who has the manual conversion stuff for a MA/GA 70
i think the guy who has the manual stuff also has a spare jza intercooler,
and the bit your after is still there stew and its yours for $50
i also have two auto boxes, 1 chaser + bellhousing +starter
and one supra with the same
RiGo
Re: JZA 70 front cut stuff Fri, 20 September 2002 07:42 Go to previous messageGo to next message
1. Is it a digital or analog dash? I'm after the clear perspex cover for the digital dash on my MA70. If so, how much?
2. Do you have the climate control unit? How much?
Cheers...
Aaron
Re: JZA 70 front cut stuff Sun, 22 September 2002 21:52 Go to previous messageGo to next message
How much do you want for the stuffed engine (with good turbos) ?
Whats broken?
Aaron
Re: JZA 70 front cut stuff Sun, 22 September 2002 23:28 Go to previous messageGo to next message
Actually how much do you want for both engines?
Aaron
Re: JZA 70 front cut stuff Sun, 22 September 2002 23:29 Go to previous messageGo to next message
and a gear box and a starter etc etc.
TOY77
Re: JZA 70 front cut stuff Mon, 23 September 2002 09:50 Go to previous messageGo to next message
sounds good.
do you want to e-mail me and we will work out the exchange...
stewbacca69@hotmail.com
Stew
JAZE
cronulla
Re: JZA 70 front cut stuff Mon, 23 September 2002 10:13 Go to previous messageGo to next message
somewhere around $1100 for both engines, auto, starter, some spares ect, also chaser mounts and your choice of front or mid sump
RiGo
Re: JZA 70 front cut stuff Wed, 25 September 2002 13:34 Go to previous messageGo to next message
JAZE: I didn't get an answer from you... Do you have the complete front cut? If so I'd be intered in the climate control unit and the speedo glass.
thnx
Sam99
Re: JZA 70 front cut stuff Thu, 26 September 2002 04:29 Go to previous messageGo to next message
Have you got the speed sensor that is bolted to the left hand side of the gearbox extension housing with one bolt? It's got three wires with a 3 pin connector coming from it. I also want the part of the wiring harness that connects the speed sensor to a connector plug in the engine compartment.
Thanks, Sam
JAZE
cronulla
Re: JZA 70 front cut stuff Thu, 26 September 2002 12:34 Go to previous messageGo to next message
i have both the afforementioned and theyre yours if you want
RiGo
Re: JZA 70 front cut stuff Thu, 26 September 2002 14:05 Go to previous messageGo to next message
JAZE wrote on Thu, 26 September 2002 22:34
ehhh...? Confused *confused* Confused
who were you replying to? what "both" do you have? If you were replying to my post and you do have the climate control unit and the speedo glass, how much pls.
Could you email me contact details to rigo_vargas@hotmail.com so I can give you a call and we can arrange it?
thnx Very Happy
[Updated on: Thu, 26 September 2002 14:07]
Sam99
Re: JZA 70 front cut stuff Fri, 27 September 2002 03:12 Go to previous messageGo to next message
If it's the speed sensor and wiring you have, please email me at sam@nw.com.au and I'll get in contact with you to arrange something.
Cheers, Sam
SupraPete
Re: JZA 70 front cut stuff Fri, 27 September 2002 06:40 Go to previous messageGo to next message
Anyone got a fog light switch??
JAZE
cronulla
Re: JZA 70 front cut stuff Fri, 27 September 2002 09:29 Go to previous messageGo to next message
sorry rigo, i meaqnt i had the bits for sam 99, i can let go of the climate control bitz but not the glass off the dash, as i cant sell the dash without it, and frebbles has already claimed it. so sorry about that but if you want the climate control stuff just e-mail me
and pete i already told you ive got the fog light switch, ill bring it over on sunday with the engine mounts Smile
RiGo
Re: JZA 70 front cut stuff Fri, 27 September 2002 11:06 Go to previous messageGo to next message
JAZE wrote on Fri, 27 September 2002 19:29
u have mail Smile
JAZE
cronulla
Re: JZA 70 front cut stuff Tue, 01 October 2002 11:27 Go to previous message
i dont think it worked, i havent got your e-mail,
you could just use a pm.
Previous Topic:12" sub and box CHEAP!!
Next Topic:17" Wheels 4 Stud
Current Time: Sun Oct 25 11:35:37 UTC 2026
Total time taken to generate the page: 0.056915044784546 seconds
