Toymods » Tech & Conversions » 1GGZE Bellhousing to G52 Gearbox
ToNkA
1GGZE Bellhousing to G52 Gearbox Fri, 20 August 2004 03:51 Go to next message
Hey all,
I was hoping someone can tell me what bellhousing I need to join my 5 speed G52 gearbox to the 1ggze engine. The g52 is out of a hilux 4x4 and the current bellhousing is larger in diameter than the 1ggze mounts.
So anyone know what I am looking for?
Also, depending on the bellhousing etc, what flywheel clutch setup do I need? Can I retain my Hilux HD clutch?
CLG
Perth, Western Australia
Re: 1GGZE Bellhousing to G52 Gearbox Fri, 20 August 2004 03:55 Go to previous messageGo to next message
Custom jobbie, there's nothing that will bolt up.
ToNkA
Re: 1GGZE Bellhousing to G52 Gearbox Fri, 20 August 2004 04:00 Go to previous messageGo to next message
I have been told that the 1G bellhousing off a W55/57/58 g/box would work, but cant find any further info on it.
I remember being told about a few 1ggte converions to toyo 4x4's and I am certain that it wasn't a custom job. Confused
CLG
Re: 1GGZE Bellhousing to G52 Gearbox Fri, 20 August 2004 04:05 Go to previous messageGo to next message
you've got me thinking now??? I've based my initial reply on the thought that the G series Toyota box is basically a R series box as found in MA70 Supras (ie, R154), and in being so, has a different style botup pattern for the bellhousing. Having typed all that and thinking about while doing so, I'm 99% confident I'm right, but am willing to be proved otherwise?
ToNkA
Re: 1GGZE Bellhousing to G52 Gearbox Fri, 20 August 2004 04:20 Go to previous messageGo to next message
Ok just called a mate, who says he is definate his Bundera has a G52 box in it (and he has the 1ggze engine). He bought it with the conversion already done, and doesnt know what the bellhousing is. He is certain it aint custom though.
Anyone? Sad
rob_RA40
c'town, NSW
Re: 1GGZE Bellhousing to G52 Gearbox Fri, 20 August 2004 04:24 Go to previous messageGo to next message
perhaps the G52 boxes are more like the W58 boxes rather than the R154, especially if it is an earlier model hilux.
ToNkA
Re: 1GGZE Bellhousing to G52 Gearbox Fri, 20 August 2004 04:30 Go to previous messageGo to next message
Its an 1984 lux. First model with the 5 speed.
Re: 1GGZE Bellhousing to G52 Gearbox Fri, 20 August 2004 04:37 Go to previous messageGo to next message
Yes, G5x boxes are closely related to W5x boxes and I've heard (but not confirmed) the bellhousings are interchangeable.
The commercial versions of the R154 have a similar model code, eg R151F.
rob_RA40
c'town, NSW
Re: 1GGZE Bellhousing to G52 Gearbox Fri, 20 August 2004 04:39 Go to previous messageGo to next message
go check out the box
u can compare them to the pics u find of the R154 and W58 in these links
http://forums.toymods.org.au/index.php?t=msg&t h=17358&rid=92&S=c5202163cebb1441b11372f45 fdb293e&pl_view=&start=0#msg_141484
http://www.speedtoys.com/~stryder/w58vsr154/w58vsr 154.html
if your box looks like a W box u may be in luck, a while ago i recall hearing that the early hilux and 4runner 4x4 boxes were the same exterior as W series boxes and the transfer case is bolted to the back of them.
and all 1G bellhousings bolt up to W55/57/58 boxes.
ToNkA
Re: 1GGZE Bellhousing to G52 Gearbox Fri, 20 August 2004 05:09 Go to previous messageGo to next message
Ok, been doing some net surfing at work and found.
http://www.4wd.net.nz/suprasurf_part2.htm
The next one is the W55.. close but no cigar. It will fit on the hilux G52 or W56 gearbox but not on the 5M-GE. But if you want to use the 2.0 litre DOHC 6 cylinder 1G engine from a Celica this is the bellhousing for you.
So its a W55 bellhousing then. So can someone tell me what these are common off?
ToNkA
Re: 1GGZE Bellhousing to G52 Gearbox Fri, 20 August 2004 05:34 Go to previous messageGo to next message
Ok adding to my own info here, (waiting for someone to confirm or not).
The W55 housing is interchangable with W56 and W57, so I should be able to use anyone of these three for the G52.
Confused
rob_RA40
c'town, NSW
u may be confused here
this website is saying that u cannot use a 1G bellhousing on a 5M-GE engine
BUT
the 1G bellhosuing will bolt up to a G52 transmission which is what u want!!!
good luck with the conversion looks like a major issue sorted Cool
this would be good information for the sticky threads up the top of the tech section.
ToNkA
Re: 1GGZE Bellhousing to G52 Gearbox Fri, 20 August 2004 05:40 Go to previous messageGo to next message
rob_RA40 wrote on Fri, 20 August 2004 15:34
BUT
Not confused, just answering my own questions and thinking out loud, waiting for someone else to chime in.
ChuckLandwehr
Re: 1GGZE Bellhousing to G52 Gearbox Fri, 20 August 2004 05:49 Go to previous messageGo to next message
My sons mate is currently fitting a 1G-GTE to a 1984 Hi Lux 4x4.
The Hi Lux came standard with a 3Y. We have used a 1G-GTE /W57-W58 bellhousing.
regards Chuck.
CLG
Re: 1GGZE Bellhousing to G52 Gearbox Fri, 20 August 2004 07:28 Go to previous messageGo to next message
Answering Tonka's thinking out aloud questions, by reading this thread, it seems yes, you can bolt a 1G bellhousing up to a G series gearbox - though as Norbie states: I've not confirmed it either. I stand corrected on the gearbox series and style, let us know if it is a definte bolt up swap?
Supralux
Re: 1GGZE Bellhousing to G52 Gearbox Fri, 20 August 2004 08:51 Go to previous messageGo to next message
you definately can. the amount of wreckers that tried to flog me one of these setups as a manual m-series bellhousing you wouldnt beleive. looks like your post on outerlimits got some info hey?
my avatar is of the g52 awaiting the m series bellhousing
[Updated on: Fri, 20 August 2004 08:54]
ToNkA
Re: 1GGZE Bellhousing to G52 Gearbox Fri, 20 August 2004 09:21 Go to previous messageGo to next message
Supralux wrote on Fri, 20 August 2004 18:51
Actually google found me the info. I posted the outerlimit thread earlier to see if anyone there had info.
Least others can use this info I hope.
ddeane
PNG
Re: 1GGZE Bellhousing to G52 Gearbox Fri, 20 August 2004 09:39 Go to previous message
and guess who has a 1gg bellhousing for sale?
Previous Topic:painting a engine block
Next Topic:3sge leaking coolant
Current Time: Thu Oct 15 17:46:25 UTC 2026
Total time taken to generate the page: 0.10143804550171 seconds
