Toymods » Tech & Conversions » 5sfe turbo, 3sgte manifold?
robbieg
5sfe turbo, 3sgte manifold? Fri, 20 August 2004 10:13 Go to next message
Hey guys, i havent been able to find a final concrete answer to this question, i was hoping someone here would know before i start buying the parts ..
Im looking at turboing my 5sfe (1990 celica sx), ive heard that the 3sgte exhaust manifold off the celica gt4 bolts onto the 5sfe motor, is this true? Also with the Burien turbo kit (poweredbytoyota.com/ssfeturbo.html) it comes with a new oilpan, what is the difference between stock oilpan and new one do you think?
CLG
Perth, Western Australia
Re: 5sfe turbo, 3sgte manifold? Fri, 20 August 2004 10:49 Go to previous messageGo to next message
I believe they bolt on. The standard 3SGTE engine has an oil return line in the pan, I'd suggest this is the reason for the replacement pan in the kit.
robbieg
Re: 5sfe turbo, 3sgte manifold? Fri, 20 August 2004 12:39 Go to previous messageGo to next message
thanks for the reply CLG Smile , can anyone else confirm / add anything to this?
RWDboy
Re: 5sfe turbo, 3sgte manifold? Fri, 20 August 2004 15:44 Go to previous messageGo to next message
Yes - 5S-FE pattern is the same as 3S-GE/GTE exhaust bolt/port pattern - I've seen this one myself many times over.
Oil drain for turbo is more than likely the reason for the replacement oil pan.
robbieg
Re: 5sfe turbo, 3sgte manifold? Fri, 20 August 2004 23:18 Go to previous messageGo to next message
do u think the gt4 oilpan fit on my 5sfe?
RWDboy
Re: 5sfe turbo, 3sgte manifold? Sat, 21 August 2004 01:33 Go to previous messageGo to next message
Yes it should Smile I'm pretty sure that the oil pick-ups are the same too? (the 3S-GE and 5S-FE ones are, I know that).
robbieg
Re: 5sfe turbo, 3sgte manifold? Sat, 21 August 2004 03:37 Go to previous message
sweet well i know what ill be doing next if i dont get my loan for mkIV supra Very Happy
Previous Topic:Is it possible to run a starlet on LPG
Next Topic:New springs and kyb shocks $928 fitted expensive?
Current Time: Sun Nov 1 08:04:49 UTC 2026
Total time taken to generate the page: 0.0047619342803955 seconds
