Toymods » Tech & Conversions » Spring on Timing Belt Tensioner (4A)
takai
Spring on Timing Belt Tensioner (4A) Fri, 20 August 2004 11:52 Go to next message
Anyone know if its really needed? I am guessing it serves as an aid to tensioning the timing belt. But if you can do this by hand then the bolt takes over the job of holding tension, and its not really needed.
Possibly also a safety device.
Anyone want to give me a definitive response?
V8_MA61
Re: Spring on Timing Belt Tensioner (4A) Fri, 20 August 2004 11:54 Go to previous messageGo to next message
leave it there, you're certainly not going to gain anything taking it off...and i doubt toyota would put it there if it wasnt really needed.
Im pretty sure its there as a safety device also Confused
juzzo84
Hornsby, N.S.W
Re: Spring on Timing Belt Tensioner (4A) Fri, 20 August 2004 14:05 Go to previous messageGo to next message
the spring is in place to give you the correct tension upon the belt before you fix the pully tight, as above poster said, just leave it there!!
takai
Re: Spring on Timing Belt Tensioner (4A) Fri, 20 August 2004 15:59 Go to previous messageGo to next message
Mmm, doesnt help when the end of the spring snaps when you are tensioning it.
I nicked one off my race engine, so ill be able to replace it later.
EVOSTi
cambo
      no
Re: Spring on Timing Belt Tensioner (4A) Sat, 21 August 2004 00:15 Go to previous messageGo to next message
you dont need it if you know how to tension it manually. its often removed on race/rally engines. only for the fact that its one less thing to break/get in the way.
takai
Re: Spring on Timing Belt Tensioner (4A) Sat, 21 August 2004 00:17 Go to previous message
Yeah, thats what i thought. But since this is my daily driver and its a bitch to get to, its nice to have a bit of safety.
The one i replaced it with was brand new, and i probably wont run one on my race engine... maybe.
Previous Topic:DIY wheel alignment
Next Topic:Gearbox Conversions
Current Time: Thu Nov 19 09:19:17 UTC 2026
Total time taken to generate the page: 0.0063400268554688 seconds
