Toymods » Tech & Conversions » Machining Wheels
SeptemberSquallIndustries
Machining Wheels Sat, 21 August 2004 12:34 Go to next message
I've just added bigger brakes to my car and found that the wheel now _just_ fouls the inside of the wheel rim against the caliper.
I want to get the wheels put on a lathe and machine out about 2mmx2mm worth of material from the inside of the rim. I realise the wheels should be balanced after this.
They're alloys.
Is this possible or safe, or should I give up now? I'll be calling a wheel machining shop on Monday but I'd be interested to hear your ideas.
Re: Machining Wheels Sat, 21 August 2004 14:58 Go to previous messageGo to next message
This is probably quite doable, but you'll probably find it's easier, safer and cheaper to just take a very tiny bit off of the caliper, even do it yourself with a grinder. Long as you use care, it should be fine.
Re: Machining Wheels Sat, 21 August 2004 15:12 Go to previous message
Fair point, thanks. Next time I'll sleep and think some more before I post drivel/crap.
Previous Topic:Interesting idea, maybe
Next Topic:Anyone ever worked/turbo'd a 5VZ-FE
Current Time: Mon Oct 26 18:31:12 UTC 2026
Total time taken to generate the page: 0.0308678150177 seconds
