Toymods » Tech & Conversions » 2tgeu Compression Probs. Advice needed.
takahashi
Outer Sydney
2tgeu Compression Probs. Advice needed. Sun, 22 August 2004 04:06 Go to next message
Hey guys,
Basically, 3 cylinders have 100psi, and one 120psi. Obviously the car doesnt really run because its on a gas research system that requires a good vacum and good compression.
I'm now at the stage where I sell the car or keep it.
The car doesnt burn any oil, water is good, no water in the oil. The engine was rebuilt 30,000km ago supposidley. So what do you think could be the problem? I'm going with a crack in the block or something like that.
If the block has a crack i wont be able to get a rebuild done i suppose.
What would the best option be?
Basically i need to fix just the engine. Everything else is fine. So i dont mind if i can just chuck out the old engine and just throw in another one. But would all the seals be fine to be run on gas? Also compression would have to be good too.
So what would u do?
I'll try get head and block numbers so we can match stuff up if need be.
Head, 17111-88266
Cant find the block code
What block does that head mate up with?
Most important thing is will the intake manifold fit with any other head?
[Updated on: Sun, 22 August 2004 04:36]
SeptemberSquallIndustries
Re: 2tgeu Compression Probs. Advice needed. Sun, 22 August 2004 04:38 Go to previous messageGo to next message
I doubt the problem would be a crack in the block, as the compression is low across all cylinders and even across three of those cylinders.
Perhaps it is a wear issue, maybe piston rings.
If this is the case, you could hone and re-ring the motor and it could work out fine.
By removing the head you can inspect the condition of the pistons and cylinder bores, valves and head chambers. If all is good, a valve grind, rings and hone could see you good.
Remember that 2T-GEU static compression wasn't high to begin with. If you're pulling the motor down to re-ring it, you may like to add some higher-compression pistons. 9.7:1 was available from factory for 2T-G.
The part number you've specified is not a head casting number. The head casting number can be found at the front of the cylinder head, to the exhaust side. Will be 11111-882##.
takahashi
Outer Sydney
Re: 2tgeu Compression Probs. Advice needed. Sun, 22 August 2004 05:13 Go to previous messageGo to next message
Rings would burn oil wouldn't they?
Also how much would i be looking at for high comp pistons?
Thanks i'll look for the head code again.
earlyrolla
Re: 2tgeu Compression Probs. Advice needed. Sun, 22 August 2004 08:12 Go to previous message
It is possible to have lower compression without burning much oil.
Have you done a wet compression test? (Put in some oil, no more than half a capful, into each bore. Let sit for a minute then re-do your compression test.)
If the compression goes up it will be rings, if it doesnt change much it will probably be valves.
Previous Topic:20v rev limmiter
Next Topic:i need a supercharger
Current Time: Sun Oct 25 22:26:26 UTC 2026
Total time taken to generate the page: 0.0038309097290039 seconds
