Toymods » Tech & Conversions » 1g-gte blowing smoke
stradlater
Arthurs Creek, Victoria
1g-gte blowing smoke Sun, 22 August 2004 11:10 Go to next message
My 1g is blowing smoke. Heaps of blue smoke when I start it up, black smoke when we are seriously on boost, periodically blue smoke just off boost and blue smoke when reving after being on boost.
Also, there is a large amount of oil acrueing near the exhaust ports on number 3&4 cylinder.
Anyone got any ideas?
Plus, my w58 (atleast I think it's the gearbox) is making a bit of a high pitched whinghing noise. Maybe the uni's?
YelloRolla
On your mum!
Re: 1g-gte blowing smoke Sun, 22 August 2004 11:29 Go to previous messageGo to next message
You may have damaged the engine, perhaps just suffed a piston. There are many variables that could cause a bit of oil smoke from valve guides/stem seals to worn rings, damaged rings or damaged piston.
To start the process of elimination I would suggest a compression test followed by a leak-down test to see if the piston/ring and valve seats are healthy.
IF a piston is damaged it should show shitloads of blow-by (lift the oil cap while the engine is running).
stradlater
Re: 1g-gte blowing smoke Sun, 22 August 2004 23:26 Go to previous messageGo to next message
Depends on your classification of blow by, but there is a reasonable bit of blow by coming out of the oil cap when lifted.
indian
south east - melbourne
Re: 1g-gte blowing smoke Mon, 23 August 2004 00:15 Go to previous messageGo to next message
piston rings
thats the same thing happend to my nissa exa turbo , blue smoke at idle after on boost ,. blue smoke at idle on lights
hope u figure out what wrong soon
also how can u tell of blowby by lifting the oil cover i need to chek mine
stradlater
Re: 1g-gte blowing smoke Mon, 23 August 2004 05:38 Go to previous message
Hrm. I would tend to agree with you. Maybe time for a new motor.
Previous Topic:Sidchrome, Kingchome,Stanley, KC tools
Next Topic:Show off valves
Current Time: Thu Nov 19 21:54:32 UTC 2026
Total time taken to generate the page: 0.0095081329345703 seconds
