Classifieds » Miscellaneous » supra JZA70 parts
TerryOBeirne
Redbank Plains,near Ipswi...
supra JZA70 parts Mon, 23 August 2004 01:27 Go to next message
left-over from a 1/2 cut. front brakes, aftermarket Jap shocks with heavy duty progressive rate coil springs (a bit lower than standard by the look), headlights & housings, bits of air-con, hydraulic fan, steering rack etc, NO panels worth having
poombah
Forrestfield, WA
Re: supra JZA70 parts Mon, 23 August 2004 01:36 Go to previous messageGo to next message
analogue dash?
power steering rack?
TerryOBeirne
Re: supra JZA70 parts Mon, 23 August 2004 03:30 Go to previous messageGo to next message
dash is gone. make me a sensible offer if you want the power rack
V8_MA61
Re: supra JZA70 parts Mon, 23 August 2004 03:49 Go to previous messageGo to next message
price on brakes? calipers and rotors?
poombah
Forrestfield, WA
Re: supra JZA70 parts Mon, 23 August 2004 04:02 Go to previous messageGo to next message
$100?
i dont know what the going rate is..
TerryOBeirne
Re: supra JZA70 parts Mon, 23 August 2004 04:03 Go to previous messageGo to next message
$200 for calipers & rotors
V8_MA61
Re: supra JZA70 parts Mon, 23 August 2004 04:18 Go to previous messageGo to next message
poombah wrote on Mon, 23 August 2004 14:02
$100?
ive got an electronic one with the controleer and everything you can have for a little more..youd have to PM me for pics and excact price.
MR 1JZ
Re: supra JZA70 parts Mon, 23 August 2004 05:51 Go to previous messageGo to next message
You still got the Cross Member??
Does anyone know if this is the X Member I will need for my 1GGTE-1JZGTE conversion in the GZ20 Soarer??
TerryOBeirne
Re: supra JZA70 parts Mon, 23 August 2004 06:33 Go to previous messageGo to next message
yep, got cross-member. dont know about the conversion. if you want it, make me a sensible offer
MR 1JZ
Re: supra JZA70 parts Mon, 23 August 2004 07:23 Go to previous messageGo to next message
Ill find out if the JZA70 supra X member is the one I need, If it is then I spose i could give you $100 for it, depending on how much it would cost to frieght the fucker over to adelaide, as they are pretty heavy yes...?
Also do you still have the mounts that bolt onto the motor??
Chris Davey
sunny coast, qld
Re: supra JZA70 parts Tue, 24 August 2004 15:03 Go to previous messageGo to next message
off the top of my head, you do need the jza70 x-member as the gz20 is rear sump right.
MR 1JZ
Re: supra JZA70 parts Wed, 25 August 2004 01:16 Go to previous messageGo to next message
Chris Davey wrote on Wed, 25 August 2004 00:33
Ill need to check up on that as my car is not currently with me...Does anyone know if the 1GGTE GZ20 soarers have a rear sump??
SUPRA MAN
Re: supra JZA70 parts Wed, 25 August 2004 02:56 Go to previous messageGo to next message
I'll give you $200 for the X member, and I can organise my freight company to pick it up from your door if you want.....
BlackSupra
Re: supra JZA70 parts Wed, 25 August 2004 09:09 Go to previous messageGo to next message
a jza70 crossmember will make your 1jz -> GZ20 a bolt in affair.
MR 1JZ
Re: supra JZA70 parts Wed, 25 August 2004 09:20 Go to previous messageGo to next message
BlackSupra wrote on Wed, 25 August 2004 18:39
Yeah but thats only if the 1JZ i get is from a JZA70?
Correct?
For instance what if my motor comes from a JZZ30 or a JZX81?
BlackSupra
Re: supra JZA70 parts Wed, 25 August 2004 09:25 Go to previous messageGo to next message
Just don't.
Buy a 1jz halfcut and it will be a bolt in affair... for everything.
too easy.
celicaboy_2000
Lismore, NSW
Re: supra JZA70 parts Wed, 25 August 2004 09:32 Go to previous messageGo to next message
You got the aircon condensor out of it? If you do what sort of nic is it in?
MR 1JZ
Re: supra JZA70 parts Wed, 25 August 2004 09:45 Go to previous messageGo to next message
BlackSupra wrote on Wed, 25 August 2004 18:55
Just don't.
too easy.
Sadly i dont really have a choice in the matter as the motor is coming in a package, which is like a halfcut but without the body parts, and becuase it is a warranty/deal with the importer/wrecker i bought the car off i dont have a say in what 1JZ he gets but it will prolly be a JZA70 becuase i have heard they are the most common...
Yes?
BlackSupra
Re: supra JZA70 parts Wed, 25 August 2004 09:56 Go to previous messageGo to next message
id say auto soarer.
But just get back on topic and buy the damn crossmember!
MR 1JZ
Re: supra JZA70 parts Wed, 25 August 2004 10:24 Go to previous messageGo to next message
BlackSupra wrote on Wed, 25 August 2004 19:26
id say auto soarer.
I cant untill my motor gets here so i can have a look at it and find out which one I actually need...
dingaling
tas
Re: supra JZA70 parts Wed, 25 August 2004 13:26 Go to previous message
Terri, do you still have the heater contol module? (the thing with controls/buttons on it that sits in the dash above the ash tray)
Last guy i asked about a heater control module ripped out the heater core and took a photo of that instead.
Previous Topic:SOLD: 13"x7JJ negative offset alloy wheels ~ DEEP DISH SUIT AE86 ^-^
Next Topic:Lotsa crap both ford and toyota! more added!
Current Time: Sat Oct 17 21:26:25 UTC 2026
Total time taken to generate the page: 0.0064280033111572 seconds
