Toymods » Tech & Conversions » Body too bad to repair??
M.W.P.
Rocky Mountains, Canada
Body too bad to repair?? Mon, 23 August 2004 04:43 Go to next message
Hi all,
Is this RA28 shell worth working on?
I bought the car for a lot more than it was worth, and as i stripped it down, i found more and more rust.
See the photos here.
The hatch it came with is almost perfect (only a little surface rust), ive got a new bonnet and doors for it.
I love the RA28's and they are very rare here in Adelaide.
Finding one without rust is almost impossible.
If i were to go ahead fixing the rust, what would be the best way to go about it?
Thanks.
M.W.P.
Re: Body too bad to repair?? Mon, 23 August 2004 04:46 Go to previous messageGo to next message
Oh, also, in the photos you can see a thick white layer under the black paint.
What is this?
Would it all need to be removed before a respray?
Re: Body too bad to repair?? Mon, 23 August 2004 04:47 Go to previous messageGo to next message
I dont reckon that would be too hard for a good panel shop to fix. My 28 had a bit of rust in it, same spot on the roof as yours (admittantly not as bad as yours though), needed a whole new section made where the spare wheel goes, same pillar rust. They were able to cut it all out and weld new metal in.
Its amazing what good panel shops can do.. My ae86 had a dint I thought never could be removed, but they got it straight as anything with hardly any filler.
Just ask around and find out who is good in your area and see them.
Joel
Re: Body too bad to repair?? Mon, 23 August 2004 04:48 Go to previous messageGo to next message
I think it should be taken back to bare metal!
M.W.P.
Re: Body too bad to repair?? Mon, 23 August 2004 04:54 Go to previous messageGo to next message
The thing that im worried about is rust coming back in 1yr time.
Could a penel/paint shop prevent the sills, etc rusting out any further?
I was considering doing a full shell acid dip & etch, but have decided i dont want to go that far.
Re: Body too bad to repair?? Mon, 23 August 2004 05:23 Go to previous messageGo to next message
I think rust always will come back in old cars. I had mine done around 3 years + ago now and a few bits have come back. I live a few mins from the beach and I dont think this helps as always salt in the air.
But when its done, make sure all the inside of the panels are rust proofed and just have to keep fingers crossed. Probably have to accept that every few years you might need to get some touch-ups done.
[Updated on: Mon, 23 August 2004 05:23]
Jag7799
Re: Body too bad to repair?? Mon, 23 August 2004 05:57 Go to previous messageGo to next message
it may be able to be saved.. but finding a cleaner less rusty shell might save u alot of money
munki
Gold Coast
Re: Body too bad to repair?? Mon, 23 August 2004 06:24 Go to previous messageGo to next message
Depends how bad you want to keep it. I seriously susgest that you keep all the good parts and wait for something else. Maybe it was meant to be and you will find an excellent shell for 500-1000 Smile
The way i see it is the more repairs the panel beater does the more things will be fucked up. It is possable for someone to fix the car but it will cost you and you will either get a shit job or a good job, but you wont know what you get until a couple of years.
I have to disagree with turbo28 that if you get it done properly there is no reason why it shouldnt last 10 years, but the trouble is finding someone that will do it properly...
and usually the best person is yourself Smile
Daniel
Jag7799
Re: Body too bad to repair?? Mon, 23 August 2004 06:34 Go to previous messageGo to next message
as for that sort of rust repair with a proper respray expect around 7-8k for a job
my car is out for a respray atm with way way WAY less rust than that, all panels taken off and all rust replaced with new metal.. all up the job is worth around 5-6k.. but im getting it for 2k(gf's dad just happens to be an awesome beater/sprayer)
fade-e
Re: Body too bad to repair?? Mon, 23 August 2004 06:48 Go to previous messageGo to next message
munki i disagree with you and agree with turbora28, my mate is a panel beater and the best job in the world would stills ee rust come back put in 3-5 years BUt rust proofing should be lifetime if done correctly
your best bet is not to wait for another shell cause that will cost you bout $1000 and that will have rust somewhere and to get that fixed will also cost BUT for bout $1000-$1500 (max cause its shell only) you can get it all sand blasted and every SPEC of rust will be gone 100%, then if you know how to weld then weld plates where required or get the panel shop to do it
now if you sand blast it, weld everything required and rust proof it THEN rust should never ever come back if you look after it correctly, ie, fish oil the inside of panels where no paint will be and rust proof paint the outside, then etch primer, primer and paint 9or you can jsut lay primer on think to cover for etch primer makes no difference at all)
for my car i am paint stripping all the panels as there is no rust on them and are straight and sand blasting the shell only to get all rust out. works out cheaper than a full sand blast
munki
Gold Coast
Re: Body too bad to repair?? Mon, 23 August 2004 06:53 Go to previous messageGo to next message
so you disagree with me but then contradict yourself and say it can last if you fix it properly... Confused ?
Re: Body too bad to repair?? Mon, 23 August 2004 06:56 Go to previous messageGo to next message
The problem I see with rust proofing is its hard to get the stuff everywhere and in all cavities etc.
When we did mine we had the hoodlining out and pumped the stuff down into the pillars and inside doors, sills, rear 1/4 panels.
But then I got a bit of rust back just under where the fuel cap is. So maybe the proofing didn't get there, or maybe moisture got under the paint? not too sure...
I just reckon no matter how good the job is now and then some will find its way back.
I wish i could remember this better but my mate who is a panel beater was explaining to me that aged metal for some reason gets rust in it. Like little hairline spider cracks kinda. Said its hard to prevent this... Sorry that isn't very technical haha but I only recall him saying it and didn't really understand it.
Re: Body too bad to repair?? Mon, 23 August 2004 06:59 Go to previous messageGo to next message
I reckon we need more panel beaters on this forum Smile
M.W.P.
Re: Body too bad to repair?? Mon, 23 August 2004 07:15 Go to previous messageGo to next message
Well if i go ahead (i think i will), ill be doing as much of the work myself as possible.
Finding a good shell i dont think is an option.
In the time ive been looking here (~18months), ive never seen a good RA28 shell for sale.
So... how does this sound for a plan:
1 - Remove windows, trims
2 - Back to metal (best way to do this with home or hire gear?)
3 - Cut out major rust
4 - Weld in new metal (i can do this)
5 - Grind back surface rust
6 - POR15 known trouble spots and new metal/weld (or even full car?)
7 - Ship off to be painted
8 - Fishoil sills, etc
[Updated on: Mon, 23 August 2004 07:23]
fade-e
Re: Body too bad to repair?? Mon, 23 August 2004 09:25 Go to previous message
i disagree in respect to just cutting and welding plates but rust proofing and fish oil combined is different
M.W.P. : fish oil before paint cause it stinks and eats paint. also you can sand over spray before going to paint
Previous Topic:is300
Next Topic:ae82 stereo wiring diagram
Current Time: Fri Nov 20 00:33:21 UTC 2026
Total time taken to generate the page: 0.036821842193604 seconds
