Toymods » Tech & Conversions » 7M crank pully removal
7mgte83
Barossa valley SA
7M crank pully removal Mon, 23 August 2004 04:51 Go to next message
is there a special trick to this because I can't get it to budge?
I need to get it off today so any imput would be appreciated
Re: 7M crank pully removal Mon, 23 August 2004 05:19 Go to previous messageGo to next message
1. Put socket and large breaker bar on bolt.
2. Wedge breaker bar against the ground.
3. Hit the starter BRIEFLY, ie just enough to crack it.
Sounds dodgy, but it worked like a charm on my 2JZ. Smile
Re: 7M crank pully removal Mon, 23 August 2004 05:37 Go to previous messageGo to next message
That will undo the bolt. Then use a puller to remove to pulley from the crank.
V8_MA61
Re: 7M crank pully removal Mon, 23 August 2004 05:41 Go to previous messageGo to next message
i had 2 people, and what i did was put two bolts in the pulley (there are threaded holes in the pulley itself) and then wedge a huge screwdriver between the two to use it as a lever so to speak, whilst the other person had the breaker bar and a piece of pipe over it.
MUCH safer than cranking the engine over if you have never done it before.
twincam_ke20
Castlemaine Vic
Re: 7M crank pully removal Mon, 23 August 2004 08:13 Go to previous messageGo to next message
and if you still cant get the bolt off to take the pulley off, heat the bolt with an oxy and then try undoing it.
Re: 7M crank pully removal Mon, 23 August 2004 08:33 Go to previous messageGo to next message
you need
WST-010: Crank Pulley Undoerer
Comon Uses: undoing crank pulley bolts (higly specialised)
http://www.rollamods.com/witzl/RA28/18RG%20Stripdown/crank-pulley-03.jpg
Re: 7M crank pully removal Mon, 23 August 2004 08:36 Go to previous messageGo to next message
and then you need special revisions of:
WST-012: 4A-GE Crank pulley remover
Comon Uses: removing crank pulley of a 4a-ge
http://www.rollamods.com/witzl/AE71%20conversion/SST.jpg
V8_MA61
Re: 7M crank pully removal Mon, 23 August 2004 08:58 Go to previous messageGo to next message
THE WITZL wrote on Mon, 23 August 2004 18:33
you need
wst ay? I have one exactly the same, bought it from supercheap a while back! Shocked
Re: 7M crank pully removal Mon, 23 August 2004 09:05 Go to previous messageGo to next message
you are a dong blake.... have you not noticed which end of the engine that is attached to, and the use of ring spanners?
Silly silly man....
ed_ma61
Lost in the K hole
Re: 7M crank pully removal Mon, 23 August 2004 09:44 Go to previous messageGo to next message
i REALLY think blake starts to pause and *think* before posting anything in future...
your run of dumb posts is increasing
V8_MA61
Re: 7M crank pully removal Mon, 23 August 2004 09:47 Go to previous messageGo to next message
THE WITZL wrote on Mon, 23 August 2004 19:05
Silly silly man....
yeah, i presumed you were talking about that pulley remover as you specialty tool.
7mgte83
Barossa valley SA
Re: 7M crank pully removal Mon, 23 August 2004 12:12 Go to previous messageGo to next message
Thank you all for the imput
I think Rolling Eyes
dingaling
tas
Re: 7M crank pully removal Mon, 23 August 2004 12:33 Go to previous messageGo to next message
Is there going to be a version of the WST-010 Crank Pulley Undoerer that will be compatible with "engine still in car"?
Re: 7M crank pully removal Mon, 23 August 2004 12:49 Go to previous messageGo to next message
Mine would work in a car. It involved a big breaker bar and and a 3 foot long aluminium pole.
Re: 7M crank pully removal Mon, 23 August 2004 13:23 Go to previous messageGo to next message
and if you ruin the faces on the bolt then you need one of these:
http://www.airliquide.com/en/img/business/industry/welding/applications/oxy-cutter.jpg
Laughing
Toobs
Re: 7M crank pully removal Mon, 23 August 2004 21:34 Go to previous message
dingaling wrote on Mon, 23 August 2004 22:33
Then you use the norbie way... wedge a big f'off bar against the ground / a crossmember or whatever and crank the engine.
Previous Topic:MR2 turbo gearbox into FWD
Next Topic:Air/Fuel Ratio gauge
Current Time: Mon Nov 2 18:13:44 UTC 2026
Total time taken to generate the page: 0.073616027832031 seconds
