Toymods » Tech & Conversions » 18RG valve recession {not the seats}
Mr DOHC
18RG valve recession {not the seats} Mon, 23 August 2004 05:39 Go to next message
if u remember, a while ago i posted a thread talking about valve recession in the 18RG heads, now i have proof, this is my INTAKE, not zorst valve out of my old head i just replaced
http://members.optushome.com.au/jag7799/phil/intakeold.jpg
allencr
tallahassee FL usOFa
Re: 18RG valve recession {not the seats} Mon, 23 August 2004 13:19 Go to previous messageGo to next message
wow! that looks seriously bad. i've never seen anything close to looking that rough & nasty on a valve face.
any chance these valves are counterfit/cheap knockoffs?
i am surprised that it isn't burned from getting towards zero lash.
Re: 18RG valve recession {not the seats} Mon, 23 August 2004 13:25 Go to previous messageGo to next message
jeez - the wear face of that is badly mashed up... contributor to your low compression issues?
Mr DOHC
Re: 18RG valve recession {not the seats} Mon, 23 August 2004 23:20 Go to previous messageGo to next message
NEAR zero lash, look at my sig for the compressions cause of the leaking valves
they are genuine
allencr
Re: 18RG valve recession {not the seats} Thu, 26 August 2004 14:12 Go to previous messageGo to next message
i still can't imagine why it looks like that, when it should be a smooth surface from the valve hitting the seat. yours looks like wear from being rotated. plus all those loose bits.
i think i could only re-create that using an electric drill chucked to the valve stem.
just curious!
wayne
Re: 18RG valve recession {not the seats} Fri, 27 August 2004 04:52 Go to previous messageGo to next message
I had the same problem with my 18RGU. Original valves with no margin left on the valve. Had the valve clearances reset but 6 months later no valve clearance and no compression.
Had to rebuild the head and replace all the valves and seats. The valves were very hard to find but finally found after a tip from someone on this site!
Shteeve
near chris and murray vic
Re: 18RG valve recession {not the seats} Sat, 28 August 2004 05:27 Go to previous messageGo to next message
what wayne said!
Mr DOHC
Re: 18RG valve recession {not the seats} Sun, 29 August 2004 07:38 Go to previous messageGo to next message
i gave it a quick spin on its seat to knock off some of the soot
i just got my head replaced, with my spare head which has new seats, new Ferrea stainless vales ect ect
Steve M
Re: 18RG valve recession {not the seats} Sun, 29 August 2004 14:08 Go to previous messageGo to next message
I imagine if you didn't upgrace the valve springs and drove it like those cams would require, this problem may become more likely.
If you hit valve bounce regularly, then this could happen, otherwise it could be due to the cam profile/timing.
Those are my guesses.
On another topic, what sort of power is that engine putting out with those cams and the valve change?
Mr DOHC
Re: 18RG valve recession {not the seats} Mon, 30 August 2004 09:16 Go to previous message
apparently its an inherent problem with the stock 18RG, my dads mate had the problem back in the good old days when he used to run one in the speedway
Previous Topic:18R - what's this?
Next Topic:lexus 4.0 V8 in hilux
Current Time: Fri Oct 23 12:45:59 UTC 2026
Total time taken to generate the page: 0.0054659843444824 seconds
