Toymods » Tech & Conversions » Install boost gauge on GT4
Sledge
Install boost gauge on GT4 Mon, 23 August 2004 07:43 Go to next message
Hey dudes where do i connect the boost gauge?
here?http://home.iprimus.com.au/tclock/pic1.jpg
[Updated on: Mon, 23 August 2004 07:44]
-==L=a=N=c=E==-
Brisbane, Queensland
Re: Install boost gauge on GT4 Mon, 23 August 2004 08:18 Go to previous messageGo to next message
Find the Map sensor, and tap into that with the T piece.
The map sensor is near the Ignitor on the firewall. Easy enough to find.
Classique71
Colac, Victoria
Re: Install boost gauge on GT4 Mon, 23 August 2004 09:48 Go to previous messageGo to next message
if you can wait 2 days or so ill show you a pic where mines tapped into - Works perfectly fine too - straight off one of the pipes from the intake manifold
Sledge
Re: Install boost gauge on GT4 Tue, 24 August 2004 00:30 Go to previous messageGo to next message
Thanks Classique71 that's what i need Smile
pictures Smile
I remember someone saying to connect it to a pipe on the intake manifold near the 'toyota' but now i can't find the post...
-==L=a=N=c=E==-
Re: Install boost gauge on GT4 Tue, 24 August 2004 01:08 Go to previous messageGo to next message
If you look behind the intake manifold there is a spare connector plug which is blanked off. Its a large vaccum line, so u'll need to step it down to run your boost gauge line off.
Ill grab a picture shortly for you to show you where i have mine running from.
-==L=a=N=c=E==-
Re: Install boost gauge on GT4 Tue, 24 August 2004 01:16 Go to previous message
http://ugbox.net/~lance/GT4/Modifications/boosttap.JPG
Srry for the blurred pic.
Anyways, this is where i have mine. The little device with the green sticker on top is the MAP sensor. There is a line coming from the bottom of it, chuck a Tee piece on that line, and run your boost gauge off it.
[Updated on: Mon, 27 June 2005 10:28]
Previous Topic:*z20 common problems
Next Topic:tiny hole in the bottom well of my radiator
Current Time: Mon Nov 2 08:13:30 UTC 2026
Total time taken to generate the page: 0.04655385017395 seconds
