Toymods » Tech & Conversions » rwd 4age distributor
$450 ta22
vic Castlemaine
rwd 4age distributor Mon, 23 August 2004 12:55 Go to next message
Can any one Tell me if there is a difference between the jdm rwd distributor cap 2 the aus ae82 fwd item as i took home a fwd cap an it didn't fit has any one else come across this problem and solved it
if so could they tell me what item i need to order
an also what rotor button i need
any help greatly appreciated
parrot
Re: rwd 4age distributor Tue, 24 August 2004 05:01 Go to previous messageGo to next message
I gather there are "a few" different cap / rotor combinations. If it is Jap spec you need, expect to visit your friendly Toyota dealer and hand over large sums of money (say roughly $140 ish for what should be a very cheap component. Better to get a complete dizzy somewhere else.
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: rwd 4age distributor Tue, 24 August 2004 13:09 Go to previous message
I sourced a RWD 4AGE dizzy cap from the US for about $25 (made by Borg Warner, just out of interest), and then found out that there's a locally delivered celica from around the same year with an identicle cap, could be ST162. A search may yield the correct model.
The rotor button is exactly the same as the local AE82 rotor, so at least that's easy.
Good luck!
Previous Topic:driveaxle hub removal FWD Celica
Next Topic:1JZ Thermostat Opening Temperature?
Current Time: Fri Oct 30 19:51:54 UTC 2026
Total time taken to generate the page: 0.0086979866027832 seconds
