Toymods » Tech & Conversions » mz20 manual conversion
73ke25
adelaide
mz20 manual conversion Mon, 23 August 2004 12:56 Go to next message
Hey guys ive searched , found a bit of info but nothing to in depth. Just wondering whats involved , how hard , how much . What are the different box options.... Tailshaft etc. Pedal box and cylinders. Just all the detials , be good if some1 whose done it before could give some info .
Thanks guys.
wilbo666
Re: mz20 manual conversion Tue, 24 August 2004 02:35 Go to previous messageGo to next message
Generally most auto->manual conversion are pretty similar (do a serach).
You have a 7m-gte right, well you can get a bellhousing to fit a W55, W57, W58 series box and the flywheel etc, or you could get a R154 gearbox and related flywheel/clutch parts (R154 was the gearbox that toyota put behind manual 7m-gte's).
W5X gearboxes are around the 300-400 mark, R154's are around the 1000-1200 mark?
Clutch pedal and master cly, prbly find a MA70 one will fit (not 100% sure, but I'd be surprised given how much they share if it didnt fit). Slave obviously depends on which gearbox you want.
Clutch line, I bent one up to fit for my conversion.
Flywheel, clutch, pressure plate, throwout bearing, and spigot bearing are also needed.
You will need to lengthen your tailshaft, or again a manual MA70 (with R154) shaft might fit, tho prbly easier just to get urs lengthened.
Also gearbox crossmember and mount (again prbly ex MA70).
I think that if you had a MA70 donor car almost everything would fit.
Jag7799
Re: mz20 manual conversion Tue, 24 August 2004 03:23 Go to previous messageGo to next message
generally a whole conversion kit(r154) will be around 2000 bucks and all bolt straight in, no drama's
as willbo said..
73ke25
adelaide
Re: mz20 manual conversion Tue, 24 August 2004 08:20 Go to previous messageGo to next message
cheers thanks for that . the r154 gearbox is pretty expensive . compared to the w5x type. Whats the difference ? is the r154 stronger or something ?
wilbo666
Re: mz20 manual conversion Wed, 25 August 2004 00:12 Go to previous message
73ke25 wrote on Tue, 24 August 2004 18:20
Toyota put the R154 gearbox behind its more powerful engines instead of the W5X, so in there opinion at least they must have thought it stronger. (the gearbox is slightly larger, and one would imagine stronger).
Previous Topic:setup for drift
Next Topic:7mge cylinder head
Current Time: Sat Nov 21 18:21:12 UTC 2026
Total time taken to generate the page: 0.0040569305419922 seconds
