Toymods » Tech & Conversions » 1JZ low idle when cold..
HedgehogSandwich
UK
1JZ low idle when cold.. Mon, 23 August 2004 18:07 Go to next message
hi all ...
My 1J idles at about 700 when cold.. has anyone got any idea what it could be?
adi
Jag7799
Re: 1JZ low idle when cold.. Mon, 23 August 2004 22:34 Go to previous messageGo to next message
HedgehogSandwich wrote on Tue, 24 August 2004 04:07
hi all ...
adi
as far as i am aware 700 is the proper idle rpm for a 1jz
thats what I was told and set mine at.
though mine does weird bouncy rev thing when i start it lol
Soarer
Wollongong
Re: 1JZ low idle when cold.. Tue, 24 August 2004 04:50 Go to previous messageGo to next message
700rpm is the factory idle at normal engine operating temp. Nothing to worry about.
Jag7799
Re: 1JZ low idle when cold.. Tue, 24 August 2004 06:18 Go to previous messageGo to next message
mine generally does a weird bouncy idle when cold and idles at 1.1k and drops down over about 30 seconds to 700
Danish
Re: 1JZ low idle when cold.. Tue, 24 August 2004 07:15 Go to previous messageGo to next message
If only I could get mine to idle at 700RPM.
HedgehogSandwich
UK
Re: 1JZ low idle when cold.. Tue, 24 August 2004 08:38 Go to previous messageGo to next message
okay thanks all.. but i mean when its COLD Very Happy ! not warm at normal operation temp. Ie it does it on first startup.. it idles at about 1000 for ten seconds then drops to 700 or lower, sometimes getting as low as 500. Surely it shouldnt drop to 700 until its at least warmed up a bit.
It never used to do this.. on a cold start it always idled at about 1500 for a bit, then dropped down over a couple of mins or so..
hope that makes sense..
adi
[Updated on: Tue, 24 August 2004 08:41]
ChuckLandwehr
Re: 1JZ low idle when cold.. Tue, 24 August 2004 10:16 Go to previous messageGo to next message
Adi, mate check the electrical connections at the front of the engine, one of them is a temp sender, which controls the cold start functions of the ECU.
regards Chuck.
JZA70_R
Brunswick, W.A.
Re: 1JZ low idle when cold.. Tue, 24 August 2004 11:53 Go to previous messageGo to next message
I'd love that, my car idles at 2000rpm when cold... I almost cry everytime I start her up Crying or Very Sad
sideshow
Re: 1JZ low idle when cold.. Tue, 24 August 2004 12:40 Go to previous messageGo to next message
could be faulty idle motor
pul it out spin the thing in middle to adjust it abit and see if it makes a difference
82MKII
Re: 1JZ low idle when cold.. Tue, 24 August 2004 12:50 Go to previous messageGo to next message
Yes - as Sideshow says it could be your ISCV.
Immediately after switching off the engine you should hear a ticking sound for a few seconds (have to listen with the bonnet up). This is the ISCV opening up for the next cold start. If you don't hear anything it may be jammed.
Regards
Peter
HedgehogSandwich
UK
Re: 1JZ low idle when cold.. Tue, 24 August 2004 15:31 Go to previous messageGo to next message
okay cheers peter.. i'll give it a listen.
Is the ISCV easy to replace? A simple in out job? Also, do i need to replace it or just clean it?
adi
82MKII
Re: 1JZ low idle when cold.. Wed, 25 August 2004 00:31 Go to previous messageGo to next message
Yes - it is easy to replace although I haven't heard of anyone replacing them, just freeing them up.
Two nuts, an air hose & a small water hose in/out and it's off.
Regards
Peter
Jag7799
Re: 1JZ low idle when cold.. Wed, 25 August 2004 04:52 Go to previous messageGo to next message
could also be fixed by something as easy as resetting ecu
HedgehogSandwich
UK
Re: 1JZ low idle when cold.. Fri, 27 August 2004 12:45 Go to previous messageGo to next message
okay ..i gtno lciking when i turn the engine off. So i'm going to remove the ISCV.
What do i do to it? clean it? can i damage anything or upset any settings?
adi
sideshow
Re: 1JZ low idle when cold.. Fri, 27 August 2004 13:13 Go to previous messageGo to next message
clean the idle motor
then this is how u reset the idle
this is for a 7m but i pressume same for 1j
run engine at 1500 revs for 5 mins
supposedly this makes the idle motor wind out and in to find its limits
do this after cleanin see if it makes a difference
HedgehogSandwich
UK
Re: 1JZ low idle when cold.. Wed, 08 September 2004 11:23 Go to previous message
well.. for some reason my idling has gone back to normal. It followed after i got stuck in traffic for three hours trying to get into silverstone racetrack...
it now idles properly at cold..drop the revs when it should at the proper times.. and it also seems quicker. odd.
oh, and i'm getting some much louder farting noises than normal on the auto shifts during high throttle.. i'm sure it was spitting flames .
[Updated on: Wed, 08 September 2004 11:24]
Previous Topic:putting bigger wheels on a car...
Next Topic:ignition
Current Time: Wed Oct 28 17:00:39 UTC 2026
Total time taken to generate the page: 0.078142166137695 seconds
