Toymods » Tech & Conversions » Camry convert to RWD
pedroenglish
icon3.gif  Camry convert to RWD Mon, 23 August 2004 21:47 Go to next message
Is there any hope in hell modding mid 90's Camry/Lexus front wheel drive to real wheel configuration?
And using a doner car and front-cut for all mech if in deed this is at all possible or actually do-able??
Can it be done?
-==L=a=N=c=E==-
Brisbane, Queensland
Re: Camry convert to RWD Mon, 23 August 2004 22:02 Go to previous messageGo to next message
With lots of money, anything is possible. But for the same amount of money you might as well buy a RWD to start with.
Benno
NSW Australia
Re: Camry convert to RWD Mon, 23 August 2004 23:17 Go to previous messageGo to next message
Go buy a Chaser if you can find one. FWD to RWD would cost a fortune and your project would no doubt stall and become a garden ornament. The structure of a FWD car does not lend itself to having the power transmitted to the road from the rear of the car, all the strength is in the front.
z|gen
Re: Camry convert to RWD Tue, 24 August 2004 02:22 Go to previous messageGo to next message
yeah..you would find it cheaper to find an LS400, which is already RWD, and also comes out with the 1UZ-FE..so its RWD and a V8, and then finding a W5* g/box i think it is, and bolting that up, with the appropriate bellhousing and wow..
also..TRD, i am pretty sure make a supercharger kit for this engine, and possibly a turbo kit..even more power from once what was a luxery car Laughing
Bugman
Re: Camry convert to RWD Tue, 24 August 2004 03:41 Go to previous messageGo to next message
isnt there a camry in newcastle running a 350 in RWD setup. I think it was done by an engineer for his wife and it uses a subframe with a camry over the top. not an easy job.
ra23celica
Re: Camry convert to RWD Tue, 24 August 2004 06:56 Go to previous messageGo to next message
One of the Camry models for sale in the USA in the mid to late 90's was a 'Camry Alltrac' which had AWD. That might be a starting point, but its a tenuous one, and whatever you do, you are looking at $$$.
Major floorpan modifications would be required to adapt / fit a rear differential as well as the axles, and I don't believe that there is enough room under a SV20-21 / SXV10 - 20 etc Australian made Camry to do all that.
If you are hell bent on a RWD Toyota sedan maybe you should look at a Chaser or Crown.
[Updated on: Tue, 24 August 2004 06:57]
Jonny2TG
Tasmania
Re: Camry convert to RWD Tue, 24 August 2004 08:21 Go to previous messageGo to next message
Some people have used all the gear from a Celica GT-4 and made a Camry 4wd with 3S-GTE engine. That is a more realistic option. The engine and everything will just bolt in, and you only have to swap in the GT-4 rear stuts and diff and everything. Still alot of work welding and cutting, but people have done it. (Or fit all of the above to a Corolla).
It would still be better to just buy a Celica GT-4. You could get a ST165 for about $9500 if you can find one.
Alainve
Newcastle NSW
Re: Camry convert to RWD Tue, 24 August 2004 08:49 Go to previous messageGo to next message
Athol mullen (the engineer)in newcastle has a magna on an old crown chassis with a V8
Jonny2TG
Tasmania
Re: Camry convert to RWD Tue, 24 August 2004 08:57 Go to previous messageGo to next message
That would be because the Crown has a seperate chassis to the body I guess, which makes that possiable. Almost like putting a Kingswood on a Landruiser chassis.
Maurice c
Re: Camry convert to RWD Tue, 24 August 2004 23:10 Go to previous message
I had an sv30 before some drunk decided that his side of the road wasn't good enough and sent it to the big breakers in the sky. Theres no way i'd even consider converting to rear wheel drive. Their pretty flimsey at the back.
Previous Topic:7mge cylinder head
Next Topic:Plug Lead Question
Current Time: Sat Nov 21 18:39:32 UTC 2026
Total time taken to generate the page: 0.0049488544464111 seconds
