Toymods » Tech & Conversions » Brake Booster Problem
adavy84
Perth, WA
Brake Booster Problem Tue, 24 August 2004 05:04 Go to next message
Ok whats happening is when the car is at idle and i pump the brakes (fast) the idle goes from 800rpm up to nearly 1500rpm.... what would cause this to happen?? i have checked the VAC line to the booster and its all fine.
Does is sound like i need a new brake booster??
ke382TG
Re: Brake Booster Problem Tue, 24 August 2004 05:17 Go to previous messageGo to next message
My previous corolla did this just days before the diaphragm inside the booster split.
The drive home after it split with un-assisted braking was interesting Rolling Eyes
May or may not be your problem though?
Re: Brake Booster Problem Tue, 24 August 2004 05:23 Go to previous messageGo to next message
Yup, my money's on a leaking diaphragm.
dar_sbb
Re: Brake Booster Problem Tue, 24 August 2004 05:44 Go to previous messageGo to next message
Its just the pressure realase of the brake booster. if ur brakes are still holding u dont need to replace it.
But if u have doubts u can just get it tested.. costs like 30 bucks to test.
[Updated on: Tue, 24 August 2004 05:45]
adavy84
Perth, WA
Re: Brake Booster Problem Tue, 24 August 2004 10:11 Go to previous messageGo to next message
Well my other corolla (same brake booster) deffently has a better feel too the brakes compared to my 4agte corolla with the upgraded front disks and calipers. But it has alot more fade so thats why im thinking its the booster.
Would it be a good idea to get the Twincam booster? im still running drums on the rear tho.
thanks for ur help
adavy84
Perth, WA
Re: Brake Booster Problem Thu, 26 August 2004 06:55 Go to previous messageGo to next message
Anyone?
Trent-KE30
Tamworth NSW
Re: Brake Booster Problem Thu, 26 August 2004 07:01 Go to previous messageGo to next message
hey man my ke30 was doing the same thing (everytime i pressed my brakes down the idle would go up and it used to lose the pressure straight away, i just got a 2nd hand one and put it on and bled the brakes and now they work fine
Trent
fade-e
Re: Brake Booster Problem Thu, 26 August 2004 08:56 Go to previous message
adavy84 wrote on Tue, 24 August 2004 20:11
thanks for ur help
mate swap the boosters and test it. would take an hour all up max...
Previous Topic:Rattlegun won't take flywheel off :( what can I do?
Next Topic:holes in boot?
Current Time: Thu Sep 10 16:40:25 UTC 2026
Total time taken to generate the page: 0.0051238536834717 seconds
