Toymods » Tech & Conversions » 1JZ Thermostat Opening Temperature?
82MKII
1JZ Thermostat Opening Temperature? Tue, 24 August 2004 05:25 Go to next message
Anyone know what the stock thermostat (90916-03093) opens at?
The local Toyota mob reckon 82 - 95 degrees - that seems too wide a range to me.
The TRD website (http://toyota-trd.jp/en/strt/thrmstut.html) sells 'sports' ones that open at 71 degrees - that seems too low.
Peter
V8_MA61
Re: 1JZ Thermostat Opening Temperature? Tue, 24 August 2004 05:29 Go to previous messageGo to next message
around 82-85" would be right. i dunno what toyota spec as the opening temp, but 82 is what my 7m opens at, doubt the 1jz would be "much" more than that.
Chris Davey
sunny coast, qld
Re: 1JZ Thermostat Opening Temperature? Tue, 24 August 2004 05:43 Go to previous messageGo to next message
I tested mine out on the weekend while swapping engines just to make sure it was working. Unfortunately no thermometer available Sad
slightly OT: how does the thermostat know what temprature it is?
V8_MA61
Re: 1JZ Thermostat Opening Temperature? Tue, 24 August 2004 05:50 Go to previous messageGo to next message
little sensor inside the spring Smile the piece just looks like your typical toyota temp sensor really!
Re: 1JZ Thermostat Opening Temperature? Tue, 24 August 2004 06:55 Go to previous messageGo to next message
Bi-metal strip actually. Two different types of metal with different thermal expansion properties are bonded together; as they heat up, one expands more than the other, so the strip bends. This is what opens the thermostat valve.
Chris Davey
sunny coast, qld
Re: 1JZ Thermostat Opening Temperature? Tue, 24 August 2004 07:13 Go to previous messageGo to next message
bloody good idea that! Smile
thanks guys
Skip
Re: 1JZ Thermostat Opening Temperature? Tue, 24 August 2004 08:13 Go to previous messageGo to next message
Theres a bit of debate out there on this one. My 1JZ sits on 90-92 degrees, so it may begin opening a little before this.
ChuckLandwehr
Re: 1JZ Thermostat Opening Temperature? Tue, 24 August 2004 08:40 Go to previous messageGo to next message
My VVTi 1JZ-GTE uses an 82 Deg C thermostat. My in radiator thermo switch turns the fans on at 85 Deg, and shuts em down at 82 Deg.
regards Chuck.
82MKII
Re: 1JZ Thermostat Opening Temperature? Tue, 24 August 2004 13:00 Go to previous message
Ok - looks like the consensus is at least 82 degrees.
Now I realise why my bottom radiator hose was stone cold after a 10 minute warm-up. The engine was only up to about 75 degrees and hence the thermostat was still shut. Looks like I'll have to wait a little longer.
Peter
Previous Topic:rwd 4age distributor
Next Topic:supercheap coolant???
Current Time: Sun Nov 1 03:54:37 UTC 2026
Total time taken to generate the page: 0.0060169696807861 seconds
