Toymods » Tech & Conversions » driveaxle hub removal FWD Celica
RobST162
driveaxle hub removal FWD Celica Tue, 24 August 2004 06:12 Go to next message
this is IMPOSSIBLE!
What is going ON HERE!
IT will NOT MOVE I am going to start breaking even more tools if I don't watch out..
CLG
Perth, Western Australia
Re: driveaxle hub removal FWD Celica Tue, 24 August 2004 07:46 Go to previous messageGo to next message
1: Remove complete hub with rotor from the car, after removing the brake calliper and steering and suspension ball joints from the hub.
2: Support the hub up off your work surface (I find working on the ground easier as you can apply more force through the hammer this way, than on a bench), and make sure you're not resting on the broake rotor - this will move with the hub as you push the back bearing off.
3: find a suitable sized socket to sit around the back of the back bearing, and protect with wood, while you hit it, slowly moving the hub and rotor in one from the back bearing. Once removed, you can undo the rotor bolts to gain acces to the front bearing if you also want to remove that, but the hub will be free of the brake rotor and hub body if thats all you want.
4: If doing wheel bearings, you can remove the front bearing with a cold chisel, destroying it in the process!
Loco
Adelaide / Sydney
Re: driveaxle hub removal FWD Celica Tue, 24 August 2004 13:24 Go to previous messageGo to next message
hey clint thanks buddy!
finally got it off... Very Happy
went down to repco, got a bigger and better breaker, + a new 30mm socket and a nice big long pipe
mwah.. therby voiding any warranty I had on the part
but I have it off finally!
I used a pry bar between the studs and resting on the ground and took it off while control arm/steering/strut were still assembled
was a very nasty and hard job
bent my sidchrome breaker quite badly
RobST162
Re: driveaxle hub removal FWD Celica Tue, 24 August 2004 13:25 Go to previous message
HAHAHAHAHAA *whoops*
Loco was at my house today.. didn't realise he was still logged in Smile
Thanks Clint!
Previous Topic:3SGE into TA-23 Qs.
Next Topic:rwd 4age distributor
Current Time: Fri Oct 30 18:09:45 UTC 2026
Total time taken to generate the page: 0.089993953704834 seconds
