Toymods » Tech & Conversions » Do I NEED a TPS?
Celica_John
Do I NEED a TPS? Tue, 24 August 2004 06:48 Go to next message
Hey just wondering if i need a throttle position sensor. I currently don't have one on the car at the moment and it seems to be running ok. It doesn't have a afm either but probably has a map sensor. Why do cars have a TPS?
p.s I'm using an aftermarket computer.
Does it mean it will run a tad lean when accelerating and a tad rich when decelerating? (i'm really just guessing here fellas)
Celica_John
Re: Do I NEED a TPS? Tue, 24 August 2004 06:52 Go to previous messageGo to next message
forgot to meantion that i've also got a crank angle sensor but i'm assuming thats just used for the ignition side of things???
Re: Do I NEED a TPS? Tue, 24 August 2004 07:08 Go to previous messageGo to next message
What kind of ECU are you running?
Danish
My MicroTech uses a Throttle Position Sensor, along with Crank Angle Sensor, Water Temp Sensor, RPM, volts, air temp sensors.
So I would say, yes it does need it.
Celica_John
Re: Do I NEED a TPS? Tue, 24 August 2004 07:15 Go to previous messageGo to next message
ems dual sport
i know the computer has an input for it.. its just that my engine doesn't have one fitted and therefore its not connected up to the computer!
fade-e
Re: Do I NEED a TPS? Tue, 24 August 2004 07:18 Go to previous messageGo to next message
my 3TGTE doesnt have one either and im using haltech F9, do i need one?
rb20det
Re: Do I NEED a TPS? Tue, 24 August 2004 08:27 Go to previous messageGo to next message
my car has a tps but it is stuffed as i get error light on mircotech come on when decelerating, what u said is true about running rich when slowing but it also runs lean when cold and idling
RA40Celica
Hobart
  chris_rg@jabber.org
Re: Do I NEED a TPS? Tue, 24 August 2004 09:53 Go to previous message
i think tps will be used for acceleration enrichment, ie when you jump on the throttle the computer will richen the mixture. just like accel. pump in a carby. It also leans the mixture when decellerating. whether you can can run without one probably depend on how nice you want your engine to run, and maybe depends on how your computer works.
it may also be used to detect a high proportion of throttle to go into open-loop mode (ie. not using the o2 sensor to correct mixtures, just run straight from fuel map in computer).
Chris
Previous Topic:Distinguishing crossmembers
Next Topic:soarer tv language conversion
Current Time: Wed Nov 25 00:38:32 UTC 2026
Total time taken to generate the page: 0.011146068572998 seconds
