Toymods » Tech & Conversions » 7M & HKS MHG
celicaboy_2000
Lismore, NSW
7M & HKS MHG Tue, 24 August 2004 09:39 Go to next message
Story so far...
1.Blocked Oringed - Copper head gasket (Leaked compression into all cylinders)
2.Orings still in place - Toyota HG (No problems, although when stripped motor down to do piston rings noticed that the usual 7M HG problem had started to form at Cyl 5)
Can I remove the orings in the block which will still leave a slight groove and use a HKS MHG?
Also I want to know if you have to get both face's machined to a really good finish? I will be getting the head faced again but to a "Mirror finish" but not sure about the block. I NEED ANSWERS Sad
bbaacchhyy
Re: 7M & HKS MHG Tue, 24 August 2004 10:44 Go to previous messageGo to next message
Don't know about the O ring saga, but there was some discussion on CS about the need/lack thereof of not "lapping" the block when using a MHG. I posted the link here some time ago, and last time I checked, there were no reports of failures.
I have a spare ACL gasket that will be used, as I don't want to rip the block out to get it decked, but we will see what happens when the boost is upped a little.
Have a search and see what you can find
Michael B
Edit : Just found it !!!!
Hi all fellow 7M users,
Just found a thread in SupraMania (US based forum), where they were discussing the merits of fitting a MHG without the much referred to lapping etc , but expoused the careful cleaning and use of "Permatex Brake Quiet" instead of the much referred copper sprays.
http://www.supramania.com/phpBB2/viewtopic.php?p=8 7091#87091
Can any of those that have used the various good gear post any opinions and also part numbers etc of the stuff that is recommended ?
As a fellow 7M-GTE owner in search of more sensible power, I will no doubt at some stage in the future be required to do this , but am all for "being prepared" in advance with any useful info.
I know people have posted with a 'generic' description and brand, eg 'Hylomar Copper Spray', but to ensure that I get the right stuff (baby), a part number would be invaluable.
Personally, loctite has always been my friend, but happy to go with others recommendations and experiences when superior to me (Nods at Ed_MA61, Allan, YelloRolla et al)
Michael B
[Updated on: Tue, 24 August 2004 10:48]
Allan
Re: 7M & HKS MHG Tue, 24 August 2004 23:50 Go to previous messageGo to next message
no way should it of leaked a stock gasket with o rings!!!! something is VERY wrong! check the ring grove make shure the rings sit level and post pics damn it!!!
Allan
celicaboy_2000
Lismore, NSW
Re: 7M & HKS MHG Wed, 25 August 2004 09:18 Go to previous message
Allan the stock head gasket wasn't leaking as far as I know, but the usual water jacket on cyl5 started to collapse. How do you post pics in Tech & Conversions? Or should I just email you the pics?
[Updated on: Wed, 25 August 2004 09:19]
Previous Topic:Microtech D5 Wiring Diagram Needed!!!
Next Topic:cams for 4age 16v
Current Time: Thu Nov 19 11:36:01 UTC 2026
Total time taken to generate the page: 0.0061368942260742 seconds
