Toymods » Tech & Conversions » Legalities of Fuel Lines/Filter placement
Legalities of Fuel Lines/Filter placement Tue, 24 August 2004 14:35 Go to next message
I am having to move my fuel filter due to that fact that it is now sitting less than an inch from the extractors, and the last thing I want is a melted fuel line and engine bay fire.
So I moving it to the place that you see in the photos.
Are there any legal reasons why I cant put it there?
Obviously it will need a stone shield covering both the filter and the lines.
Just FYI, Toyota run the fuel filters for this motor at the rear of the car as there is no room in the engine bay.
http://www.oz-enet.com.au/~peewee/eng_conv_2/fuel_setup_1.jpg
http://www.oz-enet.com.au/~peewee/eng_conv_2/fuel_setup_2.jpg
http://www.oz-enet.com.au/~peewee/eng_conv_2/fuel_setup_3.jpg
Re: Legalities of Fuel Lines/Filter placement Tue, 24 August 2004 22:41 Go to previous messageGo to next message
The location of the fuel filter shouldn't be a problem, but do something about those holes you drilled in the inner guard... use proper rubber grommets or you'll wear a hole in your fuel lines! Shocked
Re: Legalities of Fuel Lines/Filter placement Wed, 25 August 2004 00:27 Go to previous messageGo to next message
Norbie wrote on Wed, 25 August 2004 06:41
Yes yes, I do plan to do that Rolling Eyes
ra23celica
Re: Legalities of Fuel Lines/Filter placement Wed, 25 August 2004 01:14 Go to previous messageGo to next message
Peewee,
Its not worth that much but I have a copy of the WA (Police) Vehicle Safety Branch guidelines for the location of fuel lines and tanks and their clearance distances from exhaust pipes and mufflers. Its not worth much to you but its something you can show the inspectors that you considered, when the time comes. If you have a fax number, I can send it to you today.
Mitch.
[Updated on: Wed, 25 August 2004 01:15]
Re: Legalities of Fuel Lines/Filter placement Wed, 25 August 2004 01:22 Go to previous messageGo to next message
I think I have some of that printed out somewhere.
Its something like 10cm to plastic
7cm to rubber
3cm to metal
But if you are at the cruise on sunday Mitch, bring it.
Thanks.
ra23celica
Re: Legalities of Fuel Lines/Filter placement Wed, 25 August 2004 01:42 Go to previous messageGo to next message
Yes mate, you have it in one, and those figures are for a muffler to fuel tank, there are some others as well.
Would love to bring it for the cruise, but I am carless at the moment.
Maybe next time.....just like JCMF Sad
Mitch.
Re: Legalities of Fuel Lines/Filter placement Wed, 25 August 2004 09:22 Go to previous messageGo to next message
*shameless bump*
Anyone else got an opinion before I go and get the lines lengthened tomorrow morning?
Re: Legalities of Fuel Lines/Filter placement Wed, 25 August 2004 10:34 Go to previous messageGo to next message
being that close to the wheel - you might want a more substantial shield (e.g. metal not plastic) between filter and wheel in case something sharp gets picked up by the wheel and spat at the filter and thru the usual wheel-arch plastic trim at high speed. the lines will absorb a bigger hit being flexible, tho not if it's sharp.
you probably know this anyway ..
actually ... why not put the filter down at the tank? way out of harms way?
bbaacchhyy
Re: Legalities of Fuel Lines/Filter placement Wed, 25 August 2004 10:48 Go to previous messageGo to next message
Make sure the line is secured the the wheel well with suitable p-clips.
Is it possible to make the lines on the inner guard metal ?
Cover the lines with some form of spirwrap or similar (may have mentioned/thought of it already).
Michael B
Re: Legalities of Fuel Lines/Filter placement Wed, 25 August 2004 15:44 Go to previous messageGo to next message
Yeah, everything under the guard will have a metal shield on it.
I just wanted to make sure that what I proposed wasnt Illegal and hence not pass the pits when she goes over in a few weeks.
ra23celica
Re: Legalities of Fuel Lines/Filter placement Thu, 26 August 2004 00:19 Go to previous message
CrUZsida wrote on Wed, 25 August 2004 19:22
*shameless bump*
My only opinions are:
1. Yes that was a shameless plug and
2. Its obvious but get your engineer on side with this before you go over the pits in case in becomes a sticking point. If its written up already in his report you are covered.
Previous Topic:any info on gz20 soarers -- ga70 supra - workshop manual
Next Topic:Silicon hose
Current Time: Thu Oct 29 12:58:04 UTC 2026
Total time taken to generate the page: 0.11247301101685 seconds
