Toymods » Tech & Conversions » 1j parts and how to start off...
Rattlehead
1j parts and how to start off... Wed, 25 August 2004 01:46 Go to next message
Be getting a manual JZA70 half cut from CVAP - deposit down ... so now I have about 1 month to plan.
Any suggestions what sorta things I should get done to the 1JZ while engine is out before putting it in my car?
Clutch, belts, injectors?
Also, how is the parts scene for these engines. Is the soarer and supra 1jz identical when it comes to parts? Like oil filter, ignition plugs, spark plugs?
woohoo - cant wait.
[Updated on: Wed, 25 August 2004 01:50]
Chris Davey
sunny coast, qld
Re: 1j parts and how to start off... Wed, 25 August 2004 02:31 Go to previous messageGo to next message
Rattlehead wrote on Wed, 25 August 2004 11:46
Be
water pump possibly as these seem to die often. Don't know about clutch but timing belt, fan belt is a must. injectors cleaned is good idea as well. one of mine was dirty. plugs. that is all i can think of.
woohoo - cant wait.
AFAIK all 1jz's use the same oil filter and plugs. people recommend NGK BKR6ES gapped to .8mm. ignition plugs? you mean coil packs? if so, I am assuming that they are all the same.
good luck
lumpy
Adelaide, SA
Re: 1j parts and how to start off... Wed, 25 August 2004 02:56 Go to previous messageGo to next message
Rattlehead wrote on Wed, 25 August 2004 11:16
woohoo - cant wait.
Check the p/s pump, replace idler pulley bearings, give it a good clean etc. You may want to buy new engine mounts as the round rubber mounts crack/split with age. Definately a new serpentine belt (runs p/s, air-con etc), plugs, air-filter.
Enjoy!
Skip
Re: 1j parts and how to start off... Wed, 25 August 2004 05:16 Go to previous messageGo to next message
Sorry to hijack the thread, but do the water pumps start to make a hell of a rattling noise when they are nearly dead cause ive got a terrible noise coming from mine Shocked
Chris Davey
sunny coast, qld
Re: 1j parts and how to start off... Wed, 25 August 2004 05:18 Go to previous messageGo to next message
mine was leaking but not dead.
I was told the noise in my car could be the water pump and it was making a tapping/clunking noise but I worked out that it wasn't so...?
Jag7799
Re: 1j parts and how to start off... Wed, 25 August 2004 05:28 Go to previous messageGo to next message
all the stuff mentioned above.. also give it a GOOD clean while its out of the bay.. save u ages.. if u plan on polishing anything etc.. do it all while its out of the cut..
Rattlehead
Re: 1j parts and how to start off... Wed, 25 August 2004 11:23 Go to previous messageGo to next message
Thanks for the excellent replies...
Okay so far on the list:
Water pump
Idler Pulley bearings
Serpentine belt
Plugs
Air filter
Ignition leads
Clean injectors
Timing belt
Engine mounts
Hmm...this conversion seems to be getting more and more expensive. Any idea the costs of the Water pump, idler pulley bearings and timing belt?
I think timing belt will be quite a bit.
Cleaning would be wise - might be clean when I get it Very Happy
Can the engine mounts be changed after? Or is there more labour involved and better to do it from the start.
bbaacchhyy
Re: 1j parts and how to start off... Wed, 25 August 2004 11:38 Go to previous messageGo to next message
Rattlehead wrote on Wed, 25 August 2004 21:23
Just you wait till you get started Evil or Very Mad
Good luck and keep motivated and get the result
BabyZ
Armidale
Re: 1j parts and how to start off... Wed, 25 August 2004 11:56 Go to previous messageGo to next message
Depends on your point of reference Rolling Eyes. I just bought one from Penrith Toyota, and they landed it here (out in the bush) for just over $70, which I didn't think was too bad.
They do better deals (ie trade price) if you are a Toymods club member, so I am told.
(/me wonders if I should join...)
lumpy
Adelaide, SA
Re: 1j parts and how to start off... Wed, 25 August 2004 22:44 Go to previous message
Rattlehead wrote on Wed, 25 August 2004 20:53
Water pump
Serpentine belt
Plugs
Air filter
Ignition leads
Clean injectors
Timing belt
Engine mounts
Bearings are cheap - just press the knackered one out and take it to a bearing shop to match the size.
Engine mounts aren't necessary if yours are in OK condition - look for cracks around the round rubber base. New ones are around $250 per side from toyota, but you can get them cheaper if you sweet-talk the dealer. It's much easier to change the mounts when the engine is out of the car!
Now is a good time to change the suspension bushes, steering rack boots/mounts and get some new shocks too Smile
FYI my conversion from 7M-GE manual to 1JZ manual cost ~$1500 on top of the cost of the halfcut. Doing 99% of the work myself.
Previous Topic:cold start on 4agze
Next Topic:factory sw20 mr2 bov?
Current Time: Thu Oct 29 11:53:45 UTC 2026
Total time taken to generate the page: 0.062768936157227 seconds
