Toymods » Tech & Conversions » what plugs NOT to use in an 18RG
Mr DOHC
what plugs NOT to use in an 18RG Wed, 25 August 2004 02:06 Go to next message
since day one i have used platinum plugs in my 18RG, and i've always had this slight misfire, turns out that after 18 months of fucking around, all i need was a set of $12 BP6ES plugs.
DO NOT USE PLATINUM PLUGS IN AN 18RG, unless u have the ignition setup for them
Re: what plugs NOT to use in an 18RG Wed, 25 August 2004 04:02 Go to previous messageGo to next message
HAHA! didnt have electronic ignition did you?
Mr DOHC
Re: what plugs NOT to use in an 18RG Wed, 25 August 2004 08:09 Go to previous messageGo to next message
no, never have had it, want it tho
pilot
Argentina
Re: what plugs NOT to use in an 18RG Mon, 29 November 2004 05:35 Go to previous messageGo to next message
What is the best way to go electronic ignition in a 18R-G?
brett_celicacoupe
townsville NQLD
Re: what plugs NOT to use in an 18RG Mon, 29 November 2004 10:40 Go to previous messageGo to next message
THE WITZL wrote on Wed, 25 August 2004 14:02
do u mean the 18r-gu point-less dizzy, if so are the platinum plugs ok
allencr
tallahassee FL usOFa
Re: what plugs NOT to use in an 18RG Mon, 29 November 2004 18:32 Go to previous messageGo to next message
what were they gapped??
did the part # of the platinums have an "R" in it?
Re: what plugs NOT to use in an 18RG Mon, 29 November 2004 23:21 Go to previous messageGo to next message
i still wouldnt bother using platinum plugs in an 18RG... even with electronic ignition. Some NGK V-groove style will work just fine if gapped correctly on both points and electronic dizzy's.
I dont personally see the need in spending 6 times as much for a plug that lasts only about 2 times as long. Replacing your $12 plugs every 10000ks or less works for me Smile
styler
Re: what plugs NOT to use in an 18RG Tue, 30 November 2004 00:30 Go to previous message
so platnium plugs need elec dizzy,
ill remem that!
cheers never thought about it...
Previous Topic:Cressida 5M-E won't go into overdrive when warm?
Next Topic:Ta22 Suspension issue
Current Time: Fri Oct 16 20:59:47 UTC 2026
Total time taken to generate the page: 0.006112813949585 seconds
