Toymods » Tech & Conversions » Uneven Cressida
mycress
Uneven Cressida Wed, 25 August 2004 04:17 Go to next message
Hi ya!
I have a new problem with my gx60 cress. The problem is that one side of the car is lower than the other. (Driver side)
I have changed all 4 absobers (Gabriel Gas Ryder), and a GA70 front springs but to no avail.
My question... is it possible that the bushings for the front needs replacing? Any advise is useful now....
Re: Uneven Cressida Wed, 25 August 2004 06:17 Go to previous messageGo to next message
I dunno if you have a Pedders store where you live (where ever that is), but over here in the West, Pedders do a $15 suspension check where they check the whole car over, see if anything is worn.
Get that done.
tanman
Re: Uneven Cressida Wed, 25 August 2004 09:29 Go to previous messageGo to next message
sagging springs?
mycress
Re: Uneven Cressida Thu, 26 August 2004 10:06 Go to previous messageGo to next message
Well i guess that theres no Pedders in my area but i'll just a local mech to look it up for me...
as for saggin springs...i doubt it as it came off a perfectly balanced ga70.....
btw...know any other springs (street/race) which would fit a gx60??
Re: Uneven Cressida Thu, 26 August 2004 15:00 Go to previous messageGo to next message
Try the King Springs, Lovells, and Dobinsons websites.
They have online catalogues.
mycress
Re: Uneven Cressida Fri, 10 September 2004 11:57 Go to previous messageGo to next message
Dear all,
Updates on my car....
Just replaced the absober mounting (right side) and d car is still leanin to d right....Abs condition is good and springs are good as well....
I know that the fastest way outta this mess is by gettin adjustables so i may balance the car's ride height.....but b4 doin so, i would like to find out ways in resolving this...
Okay..bout adjustables, which manufacturer makes em for a GX60 Cressida?? A fren of mine suggested a S13 adjustables....Any comments???
IRA11Y
Club Member
Re: Uneven Cressida Sat, 11 September 2004 05:51 Go to previous messageGo to next message
ok firstly here in Aus GX60's arent all that common .. so where abouts are you ? cause Id love some information about some GX60 front brakes ive got sitting on my bench Smile
secondly... you said youve swapped a set of struts from another car into this one. is it possible that those struts are mounted offset in thier mount points in the other car?? perhaps it will make your car sit uneven if your mounting points are the same hieghts?
is it lower all down one side or just in the front?
what about your tyres are they all the same profile and width??
have you looked around the mount points to see if theres any damage?? maybe theres been a hard hit at some point and has pushed up the spring perch making the car sit a little lower??
mycress
Re: Uneven Cressida Thu, 16 September 2004 21:14 Go to previous messageGo to next message
Thanks for your reply mate! (IRA11Y)
Well it is lower on the front driver side (right hand side) only.
When u go over a speed bump, the right front side will 'drop' first b4 the left.
The last i checked the springs, it was level....(new absobers) btw.
Currently i'm in Malaysia. Tyres are the same width and profile.
How do you check for the spring mounts? I did change my absober mounting (which was cracked) and that did not do the job. What else should i be lookin out for ?? Thanks for your tips mate..
cheers,
1gt48u
newcastle
Re: Uneven Cressida Thu, 16 September 2004 23:49 Go to previous messageGo to next message
measure all 4 corners to see if car is square
ie if down in drivers front it should be up in
passenger rear Rolling Eyes
ChuckLandwehr
Re: Uneven Cressida Fri, 17 September 2004 07:26 Go to previous messageGo to next message
I had this exact same problem about 7 years ago!. First I measured all corner heights. Front right was low, so I swapped the front right spring! Damn that didn't work. I then swapped the left rear spring, and hey presto all good.
regards Chuck.
[Updated on: Sun, 19 September 2004 06:22]
ae95
Re: Uneven Cressida Fri, 17 September 2004 07:29 Go to previous messageGo to next message
maybe its because your sitting in the drivers side making it go down?
Re: Uneven Cressida Fri, 17 September 2004 07:32 Go to previous messageGo to next message
ae95 wrote on Fri, 17 September 2004 15:29
How can he measure it, or even see it when he's sitting in the car?
ae95
Re: Uneven Cressida Fri, 17 September 2004 07:37 Go to previous messageGo to next message
dont know maybe one of his friends noticed when he was driving
mycress
Re: Uneven Cressida Fri, 17 September 2004 17:42 Go to previous messageGo to next message
Thanks all fer ur feedback,
Chuck, did ya swapped the rear springs between left and right or u got it from another car?
Well it is noticeable when the car is parked at a level road. When i'm in d car, it didnt went down much though Smile
Any idea on wat IRA11Y was suggestin ?? I'm a newbie to these kinda things guys....
Will take out the absobers along with the discs and measure em...Just to make sure that the component (dont know wats it called) which houses the absobers are the same height....
As for the springs, any good recco as i do want to make my ride abit stiff to minimize body roll.....thanks all
ChuckLandwehr
Re: Uneven Cressida Sun, 19 September 2004 06:24 Go to previous message
Yeah sorry! I had a complete set of spare springs (in another car), so I used the lefty in the left position.
regards Chuck.
Previous Topic:Bucket Seats
Next Topic:Ign coil wiring
Current Time: Fri Nov 20 17:52:08 UTC 2026
Total time taken to generate the page: 0.007774829864502 seconds
