Toymods » Tech & Conversions » Rattlegun won't take flywheel off :( what can I do?
RobST162
Rattlegun won't take flywheel off :( what can I do? Wed, 25 August 2004 08:11 Go to next message
Compressor running between 90-100
Gun rated for 230 ft/lb
if I try a breaker bar I just pick the engine up
what do I do?????????
help please.. I am getting SO mad at the moment.. so many problems!
Mr DOHC
Re: Rattlegun won't take flywheel off :( what can I do? Wed, 25 August 2004 08:25 Go to previous messageGo to next message
some heating with an oxy torch would be an idea, the loctite that u use for a flywheel needs heating to get loose
if not, then try shocking the bolts with a hammer
disclaimer: i take no responsibility if u fuck up using these ideas
fade-e
Re: Rattlegun won't take flywheel off :( what can I do? Wed, 25 August 2004 08:28 Go to previous messageGo to next message
hammer is good option otherwise get someone to lock the front of the crank for you while your trying to loosen te bolts (with hammer too)
RobST162
Re: Rattlegun won't take flywheel off :( what can I do? Wed, 25 August 2004 08:41 Go to previous messageGo to next message
yeah I just pick the engine up with the rotation when I use the breaker
I have an impact driver here that you hit with the hammer.. would that work?
bbaacchhyy
Re: Rattlegun won't take flywheel off :( what can I do? Wed, 25 August 2004 08:44 Go to previous messageGo to next message
Yep, it should.
Keep persisting, sometimes it just takes a while Confused
Re: Rattlegun won't take flywheel off :( what can I do? Wed, 25 August 2004 08:48 Go to previous messageGo to next message
rob - get ed around
as per my previous post... 1 socket piece, 1 ratchet, 1 Ed, and my crank pulley came clean off.
give him a small breaker bar and the fly wheel should be no problem Smile
Re: Rattlegun won't take flywheel off :( what can I do? Wed, 25 August 2004 08:51 Go to previous messageGo to next message
Use some chain to bolt the flywheel from the pressure plate bolt hole to the bellhousing bolthole.
Once the slack is taken up, the flywheel stops turning. All torque is now applied directly to the flywheel bolts. Off they come.
Re: Rattlegun won't take flywheel off :( what can I do? Wed, 25 August 2004 09:11 Go to previous messageGo to next message
Also get someone to stop the motor from lifting.
Or, hit the breaker bar with a hammer, but hit downwards.
Flywheel bolts are easy compared to a crank bolt.
Fattony
Re: Rattlegun won't take flywheel off :( what can I do? Wed, 25 August 2004 09:30 Go to previous messageGo to next message
Either borrow a really good rattle gun and bump up your compressor pressure to between 100-110psi, thats usual what tools like to run at. Heat up your flywheel bolts, and if you still need to use a breaker bar, get a really fat person to sit on top of the motor. Wink
Cheers Adam
Mr DOHC
Re: Rattlegun won't take flywheel off :( what can I do? Wed, 25 August 2004 09:46 Go to previous messageGo to next message
brain not working Rolling Eyes , if he chucked a braker bar on it and hit he key would that tighten or loosen
at my work they had to do a timing belt on a CRX {old skool} and we couldnt get the flywheel bolt off, we called honda and they said they have a 1 INCH rattle gun for that, thats the same size they use to do up the V8 supercar wheel nuts Shocked
RobST162
Re: Rattlegun won't take flywheel off :( what can I do? Wed, 25 August 2004 09:56 Go to previous messageGo to next message
yeah can't hit the key bro
no starter Smile
ONE INCH! man I am in trouble......
CLG
Perth, Western Australia
Re: Rattlegun won't take flywheel off :( what can I do? Thu, 26 August 2004 03:31 Go to previous messageGo to next message
If you're still trying, I use this method when without rattle guns:
1: You'll need, flywheel socket, breaker bar, long heavy screwdriver or similar, bellhousing bolt.
2: Install the bellhousing bolt on the LHS of the engine and stand/lie on that side too.
3: Place the breaker bar with socket on the flywheel bolt.
4: Place the screwdriver under the bellhousing bolt with the head resting on the socket.
5: gripping both firmly, start applying pressure to the breaker bar until the bolt starts to undo - done!
This method moves the point of rotation from the centre of the crankshaft to the centre of the flywheel bolt you are trying to undo, I've used it relentlessly on flywheel bolts of all types, including items installed with Loctite without a problem. You'll need arm and back strength to undo some bolts, but a big hairy bastard will often help you out for the offer of a beer if you can't do it yourself?!
Re: Rattlegun won't take flywheel off :( what can I do? Thu, 26 August 2004 04:01 Go to previous messageGo to next message
Ed is such a massif dong.... Surprised
My 4ag flywheel has these nice holes around halfway long the radius which allowed me to put a long screwdriver through there and into the "wings" on the back end of the motor.
Get friend to stand on motor or hold it.... and CRACK!
RobST162
Re: Rattlegun won't take flywheel off :( what can I do? Thu, 26 August 2004 07:55 Go to previous messageGo to next message
you guys are complete champions!
ok.. well I didn't do the whole chain thing, but I was sitting there taking off my hubs and I saw my crank bolt and I thought... hmmmm why didn't I think of that...
so I got my old bent breaker and wedged it on some suspension stuff and she came off brilliantly
just about the right pressure in the right place I guess
I am bookmarking this thread too btw thanks Smile
Fattony
Re: Rattlegun won't take flywheel off :( what can I do? Thu, 26 August 2004 09:22 Go to previous message
I really doubt that you would need a 1 inch rattle gun for your application. Considering i have taken of 1g flywheel bolts on a motor that was sitting on tyre on a palet and about 8ft of the ground on a pallet rack, i did all this with a 3/8 drive socket wrench whilst standing on a ladder. GET THE MUSCLES WORKING.
Previous Topic:4AF Alternator onto a a 4AC?
Next Topic:Brake Booster Problem
Current Time: Thu Sep 10 13:44:16 UTC 2026
Total time taken to generate the page: 0.0053579807281494 seconds
