Toymods » Tech & Conversions » I want to design a calliper bracket what CAD program to use?
munki
Gold Coast
I want to design a calliper bracket what CAD program to use? Wed, 25 August 2004 11:40 Go to next message
Hi
i would like to know what an easy to learn CAD program would be if all i wanted to design was a calliper bracket?
Daniel
spectral
Re: I want to design a calliper bracket what CAD program to use? Wed, 25 August 2004 11:43 Go to previous messageGo to next message
depends on what sort of machinery you will be building the caliper bracket on.
AutoCAD is ok for general stuff, however but proper 3D modelling packages such as Solidworks are better for designing jobs for CNC milling machines or similar.
It makes the conversion in the build file a lot simplier if the design is done in proper 3D
[Updated on: Wed, 25 August 2004 11:44]
munki
Gold Coast
Re: I want to design a calliper bracket what CAD program to use? Wed, 25 August 2004 11:49 Go to previous messageGo to next message
so i would be best asking what the machinist uses and use the same? i will have a look into both of those programs as well.
Do you happen to work in a machine shop spectral?
spectral
Re: I want to design a calliper bracket what CAD program to use? Wed, 25 August 2004 12:07 Go to previous messageGo to next message
Yep, your machining shop can advise on a package that will suit. Most packages can import most formats, but its generally easier (read cheaper), to send the machine shop the drawings in the same format as they use.
yep I work in a company that has fairly substantial machining capability. I don't do the work myself (I do I.T. work), but we have 3 4-axis CNC machines, waterjet cutters and a variety of computer lathes etc.
We can do commericial jobs such as these no problems, but its important to note that we will not design the components for legal liability reasons, we simply machine them. The design and engineering is up to you and your engineer.
If you want any more details, please PM me and I can put you in touch with our sales guys to give a quote, but machining time is generally around $90 per hour. Obviously the overall time needed is dependant on the complexity/extrusions on the job.
[Updated on: Wed, 25 August 2004 12:09]
HighRolla
solidworks is great..autocad 3d i have heard is a lot harder to use.
You convert the model to code using mastercam or similar. This spits out the tooling code that the CNC machine controller understands. You can then load it into the CNC interface. Depending on how much memory the machine and complexity of part will dictate how quick this process is. CNC and CNC machinist time ain't cheap - you will have to assess it is really worth it.
[Updated on: Wed, 25 August 2004 12:14]
Re: I want to design a calliper bracket what CAD program to use? Wed, 25 August 2004 12:20 Go to previous messageGo to next message
If you don't want to go to the trouble of making drawings, you could just take your brake setup to an engineer and he'll mill a bracket to suit. This is exactly what I did.
If you like I can put you onto the workshop where my brackets were milled.
munki
Gold Coast
Re: I want to design a calliper bracket what CAD program to use? Wed, 25 August 2004 12:31 Go to previous messageGo to next message
sounds good where in brisbane though? how much did yours cost you? pm me with the details if u want
Daniel
Henn
Rosanna, Melb
Re: I want to design a calliper bracket what CAD program to use? Wed, 25 August 2004 13:01 Go to previous message
My vote is for SolidWorks, nice and easy to use and apparently the tutorials are good. And yes, you can save a file in a bunch of different formats so you can send it to different programs.
But it could be very expensive (I was quoted $700 - $500 depending on number made, although that was a pretty complex ones)
By the way, what brakes are going onto what car?
Hen
Previous Topic:Extractors
Next Topic:GT4 electric window
Current Time: Thu Nov 19 13:26:34 UTC 2026
Total time taken to generate the page: 0.058750152587891 seconds
